07-10-2017 #1
- Jul 2008
- 19
American Powertrain Hydramax Question
I was bleeding my American Powertrain HRB this weekend and while looking at it actuate something looked wrong.
Question for someone who has used this bearing... Is the entire bearing assembly supposed to move (bleeder and pressure line)? The blue anodized plate is moving in and out to actuate the clutch. It seems to me that plate should be seated against the transmission/shims and just the bearing on the front should move? It also looks like the blue plate isn't against the shims, the sleeve from the inside is pushing it away? Here is a crummy picture, best I could take without my scope. The silver you see behind the blue plate isn't the shims, it is a tube that is pushing against the shims???
I purchased this a few years back, it is a t56 on a LS motor. The bearing did come apart while I was measuring for shims, I put it back together, wonder if this is how it is supposed to work, or if I broke something? It actually seems to be working to release the clutch just not sure it is working right.
Any input would be appreciated!!!
Thanks!
