      Jan 2015
      Atlanta
      What torque converter do I need ?
      I am running a FI olds 455 with a 4l80 e and shift works controller cam specs posted below. Put it in to gear for first time today and can tell the stock van tourq converter just won't cut it, car wants to die when I put it in gear.
      what tourq converter should I run I have 373 posit Auburn gears.
      May 2015
      2400-2600 stall
      Jan 2015
      Atlanta
      Dose any one make tourq converters with longer flanges to avoid need for spacers between fly wheel and tourq converter ? ( I am using spacers since I am using a adapter plate for Chevy trans to Olds engine )
      May 2015
      Circle "D" ?
      Feb 2016
      Lawrenceville, IL
      Quote Originally Posted by Rogie View Post
      Which adapter kit are you using? Typically there is a pilot adapter to get the spacing corrected, those types of kits usually also require a special starter to engage the flexplate in its new location.
      visit us on the web at www.bowlertransmissions.com
