Deserttaco:
I read your post with your fuel system plans. The '06 GTO
fuel pump may be too tall to fit in the Chevelle tank. A 5th gen LS3 Camaro pump is a great OEM alternative that will fit depth-wise and will run on a
pwm power feed for lower fuel temps and quieter operation. One big obstacle is the 5th gen mounting flange is very large so tank mods are required or you need to purchase a RestoMod tank from Rick's Tanks that already has the 5th gen pump mounting ring. I chose the RestoMod tank from Rick's.
Vetteworks makes a fuel pump mount for the 5th gen pump that can be welded into a stock tank or a custom tank if you decided to go this route. I bought a kit from Carl at
vaporworx (Carl is a member here) that allows me to run a return-less EFI fuel system (I think this is called a dead-head system). If you install a 4th gen poppet valve in the 5th gen Camaro pump you can bypass excess fuel in the tank to regulate the fuel pressure to 58psi and run a single line to the engine - no need for a bypass regulator under the hood or a return line. My HP needs are less than 400HP so this will work great for my throttle body EFI set-up. Carl has other kits for higher HP levels and stand-alone PWM controllers if the factory ECM can't run in PWM. Here are a few pics of my parts:
5th Gen Pump and 4th Gen Poppet Valve
Attachment 143158
RestoMod Tank from Rick's Tanks
Attachment 143159
Vetteworks Fuel Pump Bucket
Attachment 143160
