    Results 1 to 9 of 9
      Dec 2014
      Murfreesboro, Tennessee
      First time engine start, run and vibration.
      Hey y'all. I finally got the car going. Once I get things sorted out I'll update my car on here. It's a 71 455. Stock bottom end. It is internally balanced. Summit racing steel flywheel. Here's what's going on. I start the motor and it idles liked it should. As I bring up the rpms a vibration appears. It's a quick vibration. It does not take that many rpms to get it to do it. When I shift gears and the rpms comes up cause the fitech is still learning I can feel it. I'm leaning towards the harmonic balancer, but I would liked some advice before I pull things apart. Thanks in advance.
      Ben
      1971 Firebird Formula 455HO 6 speed
      2017 GMC Sierra Denali Ultimate Pearl White 6.2L
      2013 GMC Sierra 5.3 6 Speed Pearl White, SLP 1.9L Supercharger(Sold)
      Mar 2015
      FL
      Make sure its not something simple like a plug wire being disconnected. And make sure you got a neutral balance flywheel since bottom end is internally balanced. Not sure how harmonic balancer would cause a vib... unless the rubber is loose or something
      -Mitch
      G8 GXP, White Hot, Auto, bone stock
      68 Firebird, 428 Pontiac, CNC'd KRE Al d-ports, hyd roller, EFI, TKO600, TCI Eng complete chassis, Ridetech, Kore3 C6Z brakes, C5Z 18" with 315 rivals x4, C6zr1 mufflers
      RRR, NASA HPDE https://youtu.be/DPp1l9-FuNE
      Dec 2014
      Flywheel is for an internally balanced motor.
      Does the vibration appear if you simply raise the RPM while not moving?
      Dec 2014
      Yes.
      Arizona
      Check the flywheel for runout and wobble. I had one that did not seat on the crank, I should have noticed, cause the transmission was difficult to stab, but it shook like a beast.
      Dec 2014
      This one isn't shaking that bad.
      Fredericksburg, VA.
      Back to the harmonic balancer, is it old or new? Stock or aftermarket?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Dec 2014
      Looking to be the flywheel. Was sold the wrong one.
