      Jun 2010
      Deployed
      ECM mounting. Is this too close??
      Location options are low!!!
      1970 Camaro/DSE build
      May 2010
      kitchener,Ontario,Canada
      I definitely wouldn't put it anymore closer , I'd say the farther away the better . So if you have room move it away a bit otherwise run it and see if it causes any issues
      Ryan Austin
      On Instagram ryanaustinss70
      Feb 2011
      dallas, tx
      Why not inside? Speartech grommet, on the firewall behind the engine
      Dec 2010
      Fredericksburg, VA.
      If you leave it there, I would suggest installing some sort of heat shielding to protect it from header heat.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Metamora, Illinois
      If it must go there I would wrap the headers.
      Jun 2010
      Deployed
      Quote Originally Posted by icemanrd19 View Post
      There's nowhere it mount it inside. I was going to put it in the wheel well but the coolant hoses took up more room then I thought. It probably got bad air flow too.
      Mountain Springs, Texas
      A simple bent aluminum heat shield will keep it cool as suggested above.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
