      Dec 2008
      Detroit
      LS2/T56 5xx DBW Engine harness
      I have a Current Performance LS2 \T56 58x DBW harness for sale. The harness is technically used because it has been installed, but the engine was never on the road. All connections are clearly labeled. There are 2 small changes I made to the harness: the wire that normally goes to the starter was extended and the VSS pigtail was changed because I have a T56 Magnum and they are different than the T56.
      Bullet connectors were used on all other connections for quick disconnect if needed. (fuel pump, speedo, tach, etc)
      This includes dual fan connections and AC
      I will also include an e67 computer that has a Stock 6.0 CTS-V tune with VATS removed.
      Retails for for $620 without EMC $450 shipped for harness and ECM
      Thanks for looking
      Full harness and fuse box
      Connection from fuse box to main harness
      Fuse panel with relays
      Quality harness connectors
      ODB2 port, pedal connection and misc wires with bullet connectors
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Apr 2010
      Los Angeles
      can you please tell me what the 58x designation is about and how do I tell if my set up has or need that? My set up is a 2007 ls2 DBW out of a trailerblazer ss (w/ stock puter) and a t56 out of a 2000 Camaro ss and just now starting to build it and will be needing a complete harness. thanks for your help
      Dec 2008
      Detroit
      Quote Originally Posted by Mofoe73 View Post
      58x is the crankshaft reluctor wheel. If yours is truly from a 2007 TBSS it will be 58x, my engine was out of an 07 TBSS also. You can verify this by checking the color of the crank position sensor located behind the starter. It should be grey in color.
      This will work for your application. Quality is excellent and the fuse box is put together better than most others I've seen.
      I will have pics this evening
      Chris--
      Dec 2008
      Detroit
      pics added
      Chris--
      Dec 2008
      Detroit
      up for new price
      Chris--
      Dec 2008
      Detroit
      sold on lat-g
      Chris--
