    Results 1 to 15 of 15
      Feb 2013
      South Carolina
      How do I tighten this plug?
      I officially have disdain for my headers. Can anyone offer some insight on how to tighten this plug? See it, buried in a nest of pipes there?
      I can get a plug socket on it but not the extension. The header pipe is in the way. I can get a wrench on the hex at the end of the socket but there's not enough room to turn it. Tried above and below.
      Is there a tool I don't know about? Not excited about moving my headers for a plug change.
      Can you get a wrench on the hex head of the socket from the bottom?
      Mar 2004
      Mid-Michigan
      Crow's Foot Wrench...
      Mark
      Mark:
      This my Bad Ast thread...
      This is my Fotki album...
      http://astroracer.fotki.com/
      Mar 2012
      Love my crow's foot wrench sets for just these kind of madenning situations. They can still be a pain in the but, but they will get it done usually.
      Aug 2005
      Hamilton, NJ
      An offset wrench often works. I had to use one on my #7 plug with my old heads. I had this old offset wrench that was perfect. Now i have angle heads so i had to cut another wrench down to fit. Homemade stubby lol
      Scott from NJ.
      Vent Windows Forever! ...
      Jonesboro, Arkansas
      I have angle plug heads as well, I have to use a box end wrench on a few of them. There have been times when I just wanted to take a big hammer to the headers to make it work, (just couldn't bring myself to do it though lol)
      Carl Wilson
      Fredericksburg, VA.
      I also have an offset box end wrench that works well for the plugs that I can't get to with a socket. In fact the offset box end works so well that I don't bother with the socket anymore.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Oct 2013
      Get a cut off wrench in there. I would be worried about the plug wire though. Hows that fit?
      Feb 2013
      South Carolina
      Quote Originally Posted by pro67coupe View Post
      I ended up getting a slip over socket for use with a wrench. It's not obvious from the picture but plug boots are not an issue.
      Jun 2010
      Deployed
      Youre right, it sure doesn't look like a spark plug wire would even fit on there. I suspect a burnt wire in your future. Poor designed headers.....
      1970 Camaro/DSE build
      Feb 2016
      Texas
      I have a tight fit plug like that as well. I use a short socket that is open on both ends and uses a ratchet that fits over it and around the outside of the socket instead of fitting on top of the socket. Works very well in tight areas like that. You can fit the socket over the plug first then place the ratchet over the socket. Mine is made by Craftsman, but other manufacturers probably make them too.
      Jan 2012
      San Jose,Ca
      What about something like this.
      https://www.ebay.com/i/232561611154?chn=ps&dispItem=1
      Tallahassee, FL
      I have a few tools I bought and others I made (for tight header clearance)
      SLP's tool:
      https://www.amazon.com/SLP-30102-Spa.../dp/B00CE2L7ZE
      Another type:
      https://www.amazon.com/Powerhouse-30.../dp/B003QYS7NO
      Have also modified a couple of bent 5/8" Box Wrenches cut off at about three inches...
      -Rich
      '72 Camaro RS/SS350: (ZZ383-TH350) Under Construction
      '88 IROC L98 (TPI 383-700R4)
      '70 VW Beetle (1600cc-Auto-Stick)
      '92 Camaro RS (Carbed 350-TKO)
      '04 Chevy Tahoe-Daily Driver (5.3-4L60E)
      '29 Ford Sedan (Carbed 350-T5 ...Grandpa's RatRod)
      Jun 2012
      South Lyon, MI
      Sometimes I just buy cheap wrenches and cut, bend and weld them until they work.
      That looks like a real challenge. I don't envy you.
      Feb 2013
      South Carolina
      Appreciate everyone's help on this - the plug's been tight for several months now and the picture really does make it look worse than it is. The open end socket worked for me.
      45 degree boots on most of the plugs actually gives me a nice air gap all around.
