      Dec 2008
      Detroit
      LS2 Crank Position sensor P0335 no start
      I'm getting a P0335 on my motor that i had running in the past, but no will not start. I did remove my harness and reconnect it when i brought the ECU inside the car. I'm wondering if something happened to the connector? I want to check the voltage which i read should be 5v for a 58x motor? Do I need to check in the key on position or during cranking? Right now no RPM's are registering in HPtuners. Any feedback is greatly appreciated.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      Jun 2011
      Brooklyn, NY
      sounds like you didnt reconnect the plug to the crank sensor behind the starter.
      Dec 2008
      Detroit
      Plug is connected that's why I now need to check the voltage at the connector.
      Chris--
      Dec 2008
      Detroit
      I think I found the issue
      Chris--
