      Sep 2016
      Bakersfield, CA
      Crankcase evac system, mufflers?
      So I'm looking at buying this kit:
      https://www.summitracing.com/parts/a...4145/overview/
      I need it bad, and looking at vacuum pump kits, that's gonna be way in my future.
      I notice it says not to run with mufflers. I have dual Flowmaster 40 series. I don't want to run with no muffler totally, do I need to go with like a Pypes Raco Pro or similar for the absolute least amount of back pressure?
      http://www.TheFOAT.com/92GTA
      1969 Pontiac Firebird
      w/BP 461ci stroker kit, 670 heads & XE274H cam. Primer black with black interior.
      Are you trying to stop oil from blowing past your seals or trying to make more HP? If you are just looking to stop the oil leaks you may want to look at an electric vac pump they cheap and work very well here is a link to an install http://grannys.tripod.com/evac.html There is a guy I work with that has one on his T-type (10.50 car) and he swears by it.
      Sep 2016
      Bakersfield, CA
      I have all forged internals and since I get oil drip out of my breathers when I go into the throttle even just a fair bit, a friend suggested this would help seal my rings better and prevent this. Said it worked wonders for him and was an old hot rodder trick. My rear main does leak a tiny bit too after some full throttle runs, and my dip stick comes out just a little. I also went up to a 195f thermostat at his suggestion as well.
      I'll take a read at the link you sent.
      Dec 2010
      Fredericksburg, VA.
      I used that kit back in the 70's when I was drag racing. That system will start working once the engine rpm gets above about 3,000 RPM. But I found it to be next to useless on the street. A properly designed PCV system will be more effective at oil control. I had small annoying oil leaks until I installed an adjustable PCV valve from ME Wagner.
      http://mewagner.com/
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Aug 2012
      Peoria, AZ
      I just recently added a MightyMouse evac can setup to my car and it works fantastic. In fact, several of my friends have done the same since and all have had similar results. Here is the link to my thread detailing how it works and what to use. http://www.lateral-g.net/forums/showthread.php4?t=54712
      Dave at MightyMouse is very helpful in designing a setup specifically for your application.
      I have done 2 full track days so far with the new setup and the engine has not used a drop of oil nor blown any oil out of the breathers.
      Lance
      Sep 2016
      Bakersfield, CA
      Sounds awesome, I'll check it out.
      Aug 2012
      Peoria, AZ
      Friend of mine lost 2 quarts of oil on one track day with his 2011 Camaro, he put a Mighty Mouse can setup on it and the next track day didn't use a drop. Controlling crankcase ventilation on newer engines that spend a lot of time at WOT is crucial...
      Lance
      Beach Park IL
      Do what Lance says. I still don't think that it should work, but it does it's job perfectly.
      Donny
