    Thread: PCV Routing
      Oct 2015
      PCV Routing
      I spent the last hour searching this website and the internet and I think I'm more confused now than I was when I started. Basically where should the tube I'm pointing to with the screwdriver be hooked to? Somewhere on the air intake between the air filter and throttle body?
      Also, my rear drivers side port is capped. Is that correct?
      its for a LS3
      Mountain Springs, Texas
      You tee the two valve cover ports together and then connect them to a port you add to your intake tube between the MAF and throttle body. That way the fresh air is metered by the MAF.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Las Vegas, NV
      That port goes to the air intake tube (after maf, as mentioned) or throttle body port (if one exists , on a DBC TB, but yours is a DBW TB, so would be air intake tube)
      see pics
      hope this helps
      Jeff
      Sep 2011
      Southern Ontario
      What is that last picture of? Off road buggy?
      Las Vegas, NV
      Quote Originally Posted by Peter Mc Mahon View Post
      Peter,
      Yes, that a pic of our new Desert Dynamics dual sport sand rail, that I just finished building
      Thanks, Jeff
      Oct 2015
      I got it all put in today. Thanks for the advice!
      Those are definitely some nice rides you have there!
