      Mar 2014
      New Mexico
      Best replacement door latch assembly???
      I have a 71 Camaro and the door latch assemblies are worn out so I ordered a replacement pair from OER and they are JUNK. Does anyone have any experience with other brands? Anyone have any OE assemblies in good condition for sale? Thanks
      Feb 2013
      El Dorado Hills, CA
      It looks like you didn't get much feedback on this question of door latches. I'm currently going through the same thing where I decided to replace my OE latches due to internal wear and I don't know what to buy. I'm thinking of replacing the springs and continuing to use them if I can't get some positive feedback on whether they make any good ones. I have read about a lot of junk from both Goodmark and OER. Did you make a decision?? Thanks
      Mar 2014
      New Mexico
      Quote Originally Posted by cwmusser View Post
      I haven't found any solutions yet. For now I'm using my stock latches, I blasted them and then greased them up real good. They work ok but the plastic latch guide is worn and doesn't "grab" the striker like I want.
      Feb 2013
      El Dorado Hills, CA
      I ended up buying OER latches through Summit (they were the only ones listed as GM recognized replacement). They made a big difference in how tight my doors shut on my new stainless strikers. Well worth the small investment.
      Ate you talking about the opening handle or the latch? Could using something like a Bear Claw from the Hot Rod guys work? Or even a latch ans striker bolt from a modern (newer) car?
      http://www.autoloc.com/catalog/Bear-...r-Claw-Latches
      Greg Fast
      1970 Camaro RS Clone
      1984 el Camino
