      Apr 2017
      Combinatio Valve Mod
      Does anyone have a diagram showing the modification required to convert the combination valve to work with rear discs on 1984 Monte SS?
      I found several dealing with the valve but my valve has a vertical valve assembly which is different than the modified valves I've found.
      Apr 2017
      I guess I could have given more info. Sorry got in a hurry.
      I'm in the process of converting my 84 Monte SS to a 9" rear with disc brakes. Just need to knows the specifics on the combination valve mod for the swap. I have a proportioning valve I will eventually install but I'm looking at getting her up and running right now. The front will be upgraded to C5/C6 next so everything can be dialed in at that point.
      I have the full UMI setup under the car with a fresh 383 stroker under the hood and the plans are to try my hand at auto cross.
      Any experienced input would be greatly appreciated.
      Dec 2010
      Fredericksburg, VA.
      To be honest you would be smart to call and visit with Tobin at Kore3.
      http://www.kore3.com/
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Apr 2017
      I've decided to replace the combo valve with the one from CPP (CH26776) that is setup for disc/disc application. once I replace the front brake I'll determine the need for a manual proportioning valve.
