    Results 1 to 11 of 11
      Sep 2016
      LA - Lower Alabama
      Fresh T56 Build - Stuck in Neutral
      I posted this on another forum, but I'm hoping someone here will have a trick up theor sleeve.
      This is my first T56 build. Everything seemed to go fine with no issues (well, until now). I replaced all the blockers, bearings, shift fork pads, keys, and springs in my T56. I set the end play and preload. Now that everything is together, the trans seems to be stuck in neutral. Input and output spin freely, but I can't shift it into any gear.
      Any my ideas on what the issue is? I would just pull it back apart and see what's going on, but I had the journal for 5/6 fixed, and now I can't pull the gear off!
      Jul 2002
      Mesquite, TX
      Can't move the stick, or it's not engaging anything?
      Sep 2016
      LA - Lower Alabama
      I can move the selector side to side (rotate the shifter rail) but can't move it forward or backward.
      Feb 2016
      Lawrenceville, IL
      Quote Originally Posted by AU Doc View Post
      It sounds like you may have one or both of the guide pins out of the rail slots. In the pics you will see the shift rail part where the guide pin rides. If the pin is in front or behind the groove it will act like it is stuck in neutral since you will not be able to slide the rail front to back. It can happen easily if you're not careful on reassembly. The case photo shows the 2 locations where the guide pins install. You can try and remove them and re-install to see if that helps, but it may be necessary to take the trans back apart to get them to line up properly. I would try the one on the passenger side of the case first as that is usually the one that can get out of track easier.
      Name:  guide pin-2 (1).jpg
Size:  226.7 KBName:  guide pin-3.jpg
      visit us on the web at www.bowlertransmissions.com
      Sep 2016
      LA - Lower Alabama
      Awesome!!! Thanks for taking the time to post that! I'm planning to pull the mid plate (hopefully tonight) and take a look. That'll be the first thing I'll check.
      Are there any good photos of how the interlock should be aligned during reassembly (edit: Let me clarify that a bit. The photos above explain how the interlock should be situated in relation to the guide pins. Now I'm wondering about how the interlocks on the 1 through 4 rail and the interlocks on the 5, 6, and R rail should be aligned)? If I screwed anything up, I think that's probably where the problem is.
      Sep 2016
      LA - Lower Alabama
      It's tough to see anything of use in these two pictures, but thought I'd post them just in case. Can anyone see any issues with the shift selector? This is looking into the transmission with the mid plate removed.
      Feb 2016
      Lawrenceville, IL
      I don't have any other photos at the moment, but looking at your last pictures I don't see anything jumping out as being incorrect. It's really tough to say what the problem could be since your guide pins are installed correctly.
      Sep 2016
      LA - Lower Alabama
      And I believe we found the problem. In attempt to keep parts in order, I left the roll-pin in the offset lever..... then I forgot about it. When I put everything back together, I dutifully put in a new roll pin. The extra roll pin wouldn't let the detent ball compress. So it was stuck in one position. Glad I figured it out before I went to the trouble of pressing 5/6 off the shaft. Now I just have to get everything back together with the mainshaft in the case.
      Jonesboro, Arkansas
      Let us know if this fixed your problem..
      Carl Wilson
      Sep 2016
      LA - Lower Alabama
      Will do. I had just about everything out of the trans with the exception of the main shaft when I found the roll pin. So now I'm struggling to get everything back together with the mainshaft in the case. I think I'm close. It took a while to countershaft and both shift rails in with the selector oriented correctly. i need to pick up some loftier and some gasket maker, and then I'll be ready to finish putting it together.
      Sep 2016
      LA - Lower Alabama
      That extra roll pin was definitely the problem! I finally managed to get everything back together last night, and she shifts through all the gears. Thanks for the feedback, everyone!
