Results 1 to 1 of 1
04-04-2017 #1
- Sep 2016
- LA - Lower Alabama
- 560
Should I replace this blocker ring that I dropped?
I posted this on one of the "other" sites, but haven't gotten any feedback. hopefully someone here can help calm my OCD.
I made a newb mistake building my T56. While setting the preload on my countershaft, I picked up my extension shaft by mistake. The Before I realized it, 6th gear fell of the shaft along with the blocker ring and thrust washer. Knocked some perfectly gear-shaped chips out of the concrete, but I think I dodged a bullet because I can't find any chips in the gear.
The only problem I can find is this tiny knick in the blocker ring and friction. The friction material is peeled back just a tiny bit. This doesn't look like a problem to me, but if this was a main bearing, i'd probably replace it just because.
Will this little knick end up cause the friction material to peel back or tear off? Is it good to run? The knick in the metal doesn't really bother me, but I am concerned about what will happen to the friction material with use.
