      Melbourne, FL
      First gen radiator pics ???
      I'm getting ready to build some mounts for the Griffin radiator for my 67. Does anyone have have some good pics of a stock radiator mounted ?? My preference would be of a pic without a motor installed so I can how high it's mounted on the core support as well as what is mounted to the support on each side. I know the battery tray is on the right side. Not sure what all is mounted on the left side.
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Feb 2009
      muggy midwest
      Doesn't it bolt to the core support like all other 67-69 fbodies?
      "...if at first you don't succeed, try again.
      If you still don't succeed, then quit-no sense being a damn fool about it..."
      -W.C. Fields
      HARNESSWORX
      (formerly gmachinz)
      Melbourne, FL
      No. It is a universal one without any mounting points.
      Sep 2016
      LA - Lower Alabama
      Here are some pics from my 69 camaro. Sorry, I don't have anything without the motor. And geez, I didn't realize how bad my radiator looks!
      Melbourne, FL
      THANKS !! This helps
