      DSE Solid Body Mount Bolt question
      Today I started installing DSE Solid Body Mounts- "Normal Ride Height."
      Rather ponying-up an extra $60 for the DSE staineles steel bolts, I purchased New OEM bolts from National Parts Depot for under $10. BUT, as I was installing the solid DSE mounts today it looks like the OEM bolts are too short! Is this correct or am I doing something wrong here??
      -Are the correct Stainless steel DSE bolts longer than the stock size bolts???
      -Should I just pick-up some longer grade 8 bolts from Pep Boys or pony up the cash for the stainelss steel DSE bolts?? Does it matter if they are not stainless steel bolts???
      Thanks, Chris
      Mar 2002
      Redwood City, CA
      Pony up the cash for the DSE stuff. It was designed for their bushings. You'll save the headache and aggravation of going back and forth to the store for parts.
      Allen Ortega
      Mar 2003
      Kirkland, WA
      Dou you have pictures? If they are stock height bushings, seems like stock bolts should work. Could you have the bushings in backwards?
      James
      -1969 Camaro Sport Coupe
      -1996 Z28
      -2005 Silverado
      Webpage
      IL/TN
      the bushing between the body and frame may be stock height but you are forgetting the bushing that is on the bottom side it is longer than the stock one making the bolt too short
      https://www.protouringf-body.com "doing what they say can't be done"
      Central CA USA
      I'd just get some grade 8 bolts at the hardware store. You do need longer than stock bolts.
      Sep 2001
      Accord, NY
      Ditto the grade 8's. I'd also suggest going to one of the better hardware stores in your area. Around me, the True Value, etc. have offshore bolts. The better store has Domestic/Canadian manufactured stuff. Id you can wait, Aircraft Spruce is a great place to shop.
      68 camaro - SOLD
      Oct 2003
      Arvada, Co
      Quote Originally Posted by zbugger
      ooooo, pretty stainless. Wait, design a bolt to bolt the frame to the car? How long did it take them do design a that? All of three seconds, thats how long. You do not need the DSE stainless ones.
      Just do what others have said. Make your way to the local bolt store and get some longer grade 8 bolts. That is what I did. I say the bolt store and not Home Depot and the like because the bolt quality will be better.
      Brian
      Newbury Park, CA
      Kyle and Stacy have likely done their homework, but there are only two companies that make stainless bolts that I would trust: SPS and ARP. ARP does not make fasteners that big, and SPS is not an off-the-shelf product.
