      Jan 2014
      NY
      ? size flywheel need advice
      400 sbc T56 magnum with a factory LS bellhousing
      can I use a 11" clutch ? will large flywheel clear ?
      Feb 2016
      Lawrenceville, IL
      Yes, you will be able to use the 168 tooth flywheel, just may want to check which starter you have. The factory starter for the smaller flywheels will not work on the larger size.
      visit us on the web at www.bowlertransmissions.com
      Dec 2010
      Fredericksburg, VA.
      I would also recommend a lighter weight flywheel. I'm running a 20 pound flywheel and it works well with my 383 SBC.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
