Results 1 to 1 of 1
03-07-2017 #1
- Feb 2017
- 52
Video for RSRT Designed Speedtech eXtreme Subframes & Chassis
To watch this In-Depth Video on YouTube ... Click HERE.
New Speedtech eXtreme Front Subframe & Suspension Package
New Cutting Edge Design Includes:
- Ron Sutton Race Technology geometry built-in.
- Strong Box type laser cut and jig welded construction - reduced weight over factory subframe.
- Special subframe width & shape allowing 315 front tires.
- Next-Gen ATS 7075 Forged Aluminum Spindles.
- High-Ackerman steering arms for ATS spindles.
- C7 heavy duty bearings & hubs.
- Speedtech high clearance upper & lower tubular control arms
- Upper control arms feature additional caster adjustability.
- Control arms powder coated gloss black and fully assembled with Delrin bushings.
- 3-piece Speedway Engineering sway bar – Choice of rates from 400# to 1300#
- Sweet racing DUAL POWER rack & pinion steering.
- Motor stands accept small block engines with OEM style mounts.
- Accepts LSX engines with Speedtech fabricated oil pan and motor mounts.
- Adjustable engine frame stands allows 3/4" fore & aft range.
- Fully adjustable rear cross member fits all GM transmissions as well as T-56 and TKO.
- Factory alignment holes offer ease of aligning frame to body and bumpers.
- Mounting hardware, instructions, and custom alignment specs.
- Comes bare. Powder coat options available.
- Built-in tow/tie down hooks eliminate strapping around painted frames.
- ridetech single adjustable coil-over shocks, including delrin thrust washers & adjusting wrench.
- Hypercoil coil-over springs – Wide choice of rates.
Base Price is ONLY $7399 + $200 crating fee
- Base Package from Speedtech includes Viking shocks & springs priced $200 less at $7199.
- Base package from RSRT automatically includes the $200 upgrade option to superior ridetech shocks & Hypercoil springs in the $7399 price.
- Ron's Digressive, High Grip, Secret Sauce Valving is available at an additional cost of $200.
Available as Bolt-In Clips for:
67-69 GM F-Bodies Camaros & Firebirds
70-81 GM F-Bodies Camaros & Firebirds/Trans Ams
68-74 GM X-Bodies Novas, Venturas, Skylark & other GM X-Body Cars
OPTIONS:
• Powder Coat Subframe – Flat Black
• Powder Coat Subframe – Semi-Gloss Black
• Powder Coat Subframe – Gloss Black
• Powder Coat Subframe – Gun Metal Grey
• Powder Coat Subframe – Silver
• Billet Aluminum Body Mount Set
• Engine Bay Round Tube Chassis Down Bar Supports
• Double Joint Steering Shaft Kit
• LSx Engine Adapter Plates
• Speedtech 1 7/8" LSx Headers, Mill Finish
• Speedtech LSx 1 7/8" Headers, Show Polished Finish
• Ron Sutton Tailored Suspension Tech Service #40STP
• Ron Sutton Tailored Brake Tech Service #29
• Ron Sutton Secret Sauce Digressive Track-Star Valving added to Ridetech Single Adj Shocks
• Ridetech Triple Adj Shocks w/Digressive Track-Star Valving
• JRI Shocks w/Digressive Track-Star Valving in Single, double or triple adjustable
So You Get ...
* The highest performing front suspension & steering
* A Balanced Suspension Package Tailored to Your car
For more information ... OR To Place Your Order ... Contact Ron Sutton Race Technology:
Phone: (844) 722-3832 ext.#3
Email: [email protected]
Address: 11374 Amalgam Way, Suite K, Gold River, CA 95670
Website: www.RonSuttonRaceTechnology.com
