Thread: LT1 oil pressure
11-19-2005 #1
- Aug 2004
- England
- 1,042
LT1 oil pressure
Bit worried, when on tickover about 850 revs and when up to temp the oil pressure is about 15-18 psi, when throttle is pressed it goes up to 45psi , its a 95 LT1 vette, the engine is standard insides running mobil 1 oil .
paul67
11-19-2005 #2
Starting The Transformation
- Nov 2005
- 130
Paul,
I build a lot of these engines, and that is extremely low for that motor. 25psi about as low as I want to see in a stock bottom end.
What I shoot for is 35-40psi at idle and 55-60psi max.
My guess is that the motor wasn't running Mobil 1 it's whole life, so now with it in there the increased clearances cause your low oil pressure.
5w-30 M1? You might want to switch to a 40W M1 and see what that does.
BretBauer Racing Engines
Specializing in late model GM motors
1964 GTO (work in progress for 13 years)
600 HP 365 cube SBC
C5 Front Suspension
Satchel Link Rear
T56
Not gettin done anytime soon
2000 Camaro SS SCCA FS Car
Koni Adjustables
35mm Front Bar
DOT Race tires....
11-20-2005 #3
- Aug 2004
- England
- 1,042
OK thanks
paul67
