Thread: Rattle can Aluminum primer
03-03-2017 #1
- Aug 2004
- Connecticut
- 847
What is a good rattle can self etching primer for a T-56 magnum? it is a new tranny what should i clean it with before primer?
thanks
Paul Krol
1968 Camaro
03-03-2017 #2I had good luck with SEM Products
https://www.amazon.com/SEM-39683-Gre.../dp/B000GTIRAU
03-04-2017 #3Just keep in mind that anything from an aerosol can is nothing more than laquer based and is a single component product. Personally I don't trust any of it. But, it is just the trans and will probably be fine.
I knew a guy that used a 1k primer on his all steel 32 Ford as a etch. Then spent 7 years and tons of $$ redoing the car. Only to have the paint start to fall off the car later on due to the improper initial priming.
Glenn
1955 Chevy BelAir
1951 Chevy 3100
1987 Chevy Silverado
My last project....
https://www.pro-touring.com/threads/...my-72-Maverick!!
03-04-2017 #4The exception to this is 2K rattle cans. I'm not working for Eastwood anymore, but they have a great product with 2K aerospray catalized products. about $25.00 per can, 48 hour pot life, great performance and durability.... Pro products in a rattle can, just sayin. CHeck em out. I'd go epoxy on the (cleaned) aluminm, then follow with whatever paint you choose. Anything with a catalyst is obviously better and stronger.
KTMy hybrid burns gas and tires....
03-04-2017 #5
Glenn
1955 Chevy BelAir
1951 Chevy 3100
My last project....
03-04-2017 #6
