    Results 1 to 14 of 14
    Thread: CNC heads
      Oct 2005
      Florida
      CNC heads
      What is the average HP gain for CNC ported, polished chambers and a 3 angle valve job cylinder head? Is it worth it or should i buy some AFR or Darts for my SBC camaro?
      -Rob
      1969 Chevy Camaro 350-8th cylinder gone =[-
      2005 Dodge Viper SRT-10 505/ 510hp
      The CNC port is only as good as the program and the orginal port it was designed after.
      Most times yes porting by hand or by CNC machine is beneficial but you have to make sure you pick a good head porter.
      My preference in motors is to start off with a as cast head that is smaller than what I need and have the head ported. I would say that 75% of the time I opt for hand porting due to the uniqueness of the situation with the engine where a CNC program doesn't fit the bill for the heads.
      Bret
      Bauer Racing Engines
      Specializing in late model GM motors
      1964 GTO (work in progress for 13 years)
      600 HP 365 cube SBC
      C5 Front Suspension
      Satchel Link Rear
      T56
      Not gettin done anytime soon
      2000 Camaro SS SCCA FS Car
      Koni Adjustables
      35mm Front Bar
      DOT Race tires....
      Santa Barbara, Ca
      I'm not sure of your application, but it's hard to go wrong with AFR heads. All of their heads are "CNC ported". In each intake runner size, they offer both a basic head (which has cnc'd ports) or a competition package head that is 100 % CNC ported. I saw a set of their 195cc competition package heads on a fairly mild 420ci small block put out 550hp on the dyno. Pretty impressive for a relatively small head. IMOP, when you buy a head like an AFR, you are getting proven performance. You know what you're getting. Just my 2 cents.
      -Andy
      Than again i've seen a AFR BBC head get smoked by a well done Edelbrock head. Yes you know what you are getting but I don't really think they are the be all end all of heads. FWIW I'm not a huge fan of AFR heads.
      Bret
      600 HP 365 cube SBC
      C5 Front Suspension
      Satchel Link Rear
      T56
      Koni Adjustables
      35mm Front Bar
      DOT Race tires....
      Oct 2002
      Houston,TX
      I am about to build a blown SBC and use a set of Dart heads, And have my motor builder port them.
      James J.
      Nov 2003
      Paradise, Ca
      Why is noone talking about Brodix or Pro-Topline of New Zealand? Both offer CNC machined ports, and both are outstanding heads, with excellent customer service.
      In my opinion, CNC machined ports are only worth the money if you just happen to be running the same combination that the ports were designed for. If not, working with a good head porter will do wonders.
      -Matt
      Pro-Topline is now RHS owned by Comp.
      As for the Brodix stuff, I've used the Weld Tech CNC ported T1's and have made 600hp out of a street 365 cube motor.
      Bret
      600 HP 365 cube SBC
      C5 Front Suspension
      Satchel Link Rear
      T56
      Koni Adjustables
      35mm Front Bar
      DOT Race tires....
      Nov 2003
      Paradise, Ca
      Bret, do you have any more info on the Pro-Topline move to RHS? I went to the RHS website and under small block heads, all they have listed is a 23º head. I'm more interested in the 12º and 14º heads.
      Also, Pro-Topline's NZ website is unchanged.
      -Matt
      Nov 2003
      Maine
      matt
      nt sure about the website but i saw rhs at sema and they had a as cast version of there bigblock heads and are working on getting the cnc ones done, he said it will be a few months but they will get them perfect.
      jake
      I cant get on to Pro Top Lines site but that's where RHS came from. I know a few people that are looking forward to seeing the shallow angle cast iron heads for some drag racing classes.
      My rep at Comp Cams moved over to RHS, I'll ask him what the deal is on the shallow angle heads when I'm at PRI.
      Bret
      600 HP 365 cube SBC
      C5 Front Suspension
      Satchel Link Rear
      T56
      Koni Adjustables
      35mm Front Bar
      DOT Race tires....
      Ontario, Canada
      Quote Originally Posted by SStrokerAce
      Bret
      While you're talking to him, ask him to talk to someone about their (RHS) web site. Compared to AFR's web site, RHS's is little more than a sales pitch. If they want to make a sale, they need to offer some real technical information on their product.
      Ken
      My other car is a Vega.
      Nov 2003
      Paradise, Ca
      Ken, I know what you're saying, but if they are truly carrying Pro-Topline stuff, then that's good enough for me.
      Bret, I would appreciate it. I've had my eye one the Pro-Topline 14º heads for a few years now, wishing I had something to put them on. Either those or the Brodix 12º heads.
      -Matt
      Santa Barbara, Ca
      Quote Originally Posted by Fbody69
      -Rob
      Back to Rob's question. Everybody has their personal favorite brand and opinion on what head is best. What head you need really comes down to the engine size, combination and intended use. Any good quality, properly sized aftermarked head will be a huge improvement over an old, stock cast iron head. They all come with performance valve jobs and 2.02" (or larger) valves. Trick flow makes a great 195cc head for the money. It really depends on what you want out of the engine. If you give us a little more info we might be able to steer you in the right direction.
      -Andy
      Ontario, Canada
      Matt, I've checked out Pro- topline's web site and found some very impressive heads. If the RHS porting quality can also be re-established with the name, they should be awesome heads. That's where the need for flow charts and such come in. Even if the manufacturers numbers are suspect, it at least gives you something to compare heads with.
      Andy, I think you pretty well nailed it. Port requirements change for applications, engine size, and even driver preferrence.
      Ken
