    Results 1 to 1 of 1
      Oct 2016
      MC/booster upgrade questions
      I just got my car back on the road last year and was using the stock MC/booster with the new fbody upgrade front and rear brakes. I did swap the proportioning valve for an adjustable one from SSBC, took the pressure residual valve out and stock proportioning valve too. Only issue is I have low brake pressure which I knew was going to be the outcome but suprising it wasn't too bad. But now I've got to get this done.
      I was looking into doing the S-10 MC upgrade and found the part number #18M974, but I need the part numbers for the booster to use with this and associated parts like mounting brackets and clevis if anyone knows off hand
