      Feb 2015
      Car won't start - suggestions please...?
      So, a little history...
      I have a 67 camaro with a 383 in and a holley commander 950 controlling the EFI. Everything was working well last May... some fine tuning needed on the fuel & spark maps but you could happily drive it around without issue.
      Had some storage issues at the house and rented a storage space to put the car in, thinking i'd go back and use it more than I did. The tank had stabil in there though to be safe. Long story short, life & work got in the way last summer and i didn't get back to the car to drive it. battery was disconnected though...
      Fast forward to this weekend, I wanted to bring it back to the house, clean it and start work on the tuning. went to get the car on Friday... reconnected battery, plugged computer in, checked the settings.... turned the engine over a few times without the ECU on to get oil pressure back... plugged ECU in... the first time i cranked it, it was firing but wouldn't start. Retarded the timing a little in the computer at idle speeds, cranked it, car sprang to life but the awfully crappy software showed that all timing values had reset to zero. Turned it off, reloaded the map and have since spent the rest of the weekend trying to start it again.
      Things I've tried...
      New battery
      New fuel (siphoned the old tank, put 5 gallons of fresh 93 in there) it has a return line to ran the fuel pump to get fresh into the rails.
      Old maps (known good)
      New maps (just in case)
      multiple adjustments of throttle blades to more/less air in, depending on my mood & frustration level.
      Every now and then, you can hear it firing, other times, there's absolutely nothing. I've played with the cold start enrichment values, starting small and working higher to the point that you can smell that it's flooded.
      Any suggestions? I'm at my wits end with this and am at the point of selling it, I don't really want to go blindly chasing ghosts with new injectors & so on so thought i'd come to the place with a ton of experts and see a) what i did wrong (apart from failing to winterize it) and b) how i fix what i've done.
      But, if anyone's looking for a pretty sweet/complete camaro that just needs a pretty LS & 6 speed in it.. today's a good day to give me a call...
      Tom
      Aug 2015
      NJ
      First thing I would check is all the fuses. Had a car that sat for the winter, hooked up the battery and tried firing her up and it started but ran all choppy - turned out to just be a fuse. Sounds like it is getting fuel if you are smelling it so I'd check more closely into the electrical - maybe a mouse got to your wiring?
