    Page 2 of 2 FirstFirst 1 2
    Results 21 to 32 of 32
    1. #21
      Nov 2012
      Quote Originally Posted by colt6920 View Post
      Well I suppose I'm in the same boat here for going to a GoodGuys autocross, my biggest questions are what time on Friday would I need to be there to be able to go out and walk the course,as well as do they provide us with any sort of map of the course? Then where do we go to pass tech inspection especially at the Scottsdale events? Also if we aren't in the proclass where can we park our vehicles between runs? Can we keep them up in the main areas with the other cars or where can we go? Thanks!
      Walking the course wasn't very helpful to me as a first timer - the course is marked so well you aren't going to get lost and take out a bunch of cones. It was much more helpful to watch the lines everyone took. No maps. As far as where you park, there's a line that forms much like a check out line at Wal-Mart - the earlier ones get a spot closer to the start, and the driving order just keeps going around as you park back in the spot you had when you finish your run. Even if you leave to go check out some other stuff you can leave your car there, but as a courtesy you should let the next guy in the rotation that you're leaving so they won't be waiting on you.
      _______________
      1969 Camaro
      1966 Skylark
      1964 Lemans
      1960 Biscayne
      Steve
    2. #22
      Feb 2009
      Laramie, WY
      Hope you had fun. That is the main thing to do. I took my wagon with the stock 71 Suspension and motor out. in 2013. I still think you can see where the tires rolled over. Do I care, Nope had a blast.
      Tim
      1971 Buick Sportwagon pro-touring project. Buick 455 TH350, SPC front suspension, UMI rear suspension, KYB shocks, Slowly getting there.
      1985 Ford Crown Victoria 2 door next project.
    3. #23
      Aug 2011
      Granite City
      I'm working on putting together a suspension that will allow me to do some corner carving this year. More than likely my first event to AutoX will be on Hot
      Rod powertour this as im planning to do long haul.
      Concerns as a rookie that cross my mind.
      -Bench seat and Lap belts? Hope to upgrade to shoulder belts soon... But will it fly? May make it tough for driver.
      -Fuel starvation issues with stock non-baffled tank- I assume I will just make sure its full to avoid potential issues here...
      -Oil starvation issues. I have a mild LT1 in my car with a Moroso pan, but its no trap door/baffled pan.
      Am I over thinking these issues? It seems a road course would be maybe more cause for concern on these?
      I have plans to address most of these... But it won't be until next season. I would like to get my feet wet this year at least to have a feel. So far the majority of people I have interacted with that are in the pro-touring community have been fantastic and overly helpful. Im excited to be involved in that type of hot rodder net work, as well as pure driving involvement.
    4. #24
      Central CA USA
      Quote Originally Posted by beater65 View Post
      The bench seat is going to suck. See what you can figure out to belt yourself in as best you can. Sixties bucket seats suck too. A good bucket seat with lateral support is VERY desirable.
      Do you have EFI? if it's a carb it shouldn't be starving, might be flooding. I run Holley dual inlet type carbs at the minimum float level setting.
      Filling the tank is a good idea, it also helps rear traction. Make sure your gas cap does not spill fuel.
      SB Chevys pump a lot of oil up to the rockers. This can cause oil starvation issues. Overfill your oil level by 1/2 quart. Never run it below the full mark. I towed a Corvette autocrosser home TWICE with spun bearings because he starved for oil at an autox. He ran below the add oil mark, forgot to check it TWICE!!!
      Check your PCV breather system. The factory puts the PCV valve in the valve cover left front position. The valve cover must have internal baffles, adding some mesh can help prevent oil from getting sucked into the PCV hose. We have found that to be the best location. I highly recommend running a PCV vave, it helps oil drain back.
    5. #25
      May 2015
      Nashville, TN
      Quote Originally Posted by TonyV View Post
      Hey question here for a "first timer" i'm thinking about doing a March event but my car isn't "finished" yet, well are they ever finished? Its primer'd and no interior other than seats. Is it appropriate to enter it in "raw" form? just wondering because I wanted to track the car for ~1yr before I painted it and work out the bugs. I did a road course event last month and realized I needed to add a PS cooler but wanted to do an autocross event also for the same reason.
      As long as you're street legal, you're Goodguys legal. (Registered, with standard safety equipment required to be street legal)
    6. #26
      May 2015
      Nashville, TN
      So glad you gave it a try and were able to realize that it really is a sport for everyone. Welcome to the addiction.
    7. #27
      Dec 2010
      Peoria, AZ
      Quote Originally Posted by David Pozzi View Post
      With our last SBC we ended up using an elbow on the valve cover (in the factory PCV position) and about 6 inches of hose to put the PCV in-line but off the valve cover. Even with baffles, we were getting enough oil soak to ruin a PCV every 3 - 6 laps depending on length of run. As a daily, it was never an issue but at 7000 rpm, we had issues on course with the PCV getting oil soaked and sticking open leading to a vacuum leak and stalling problems in corners during the throttle transition. It wasn't a very pretty setup, but it was effective.
      Tom Pichette
      Pit crew for Valerie Pichette and her 1988 Pontiac TransAm GTA "DragonLady"
    8. #28
      Aug 2011
      Granite City
      I plan to do some buckets at some point in time with bolstering. But won't be this season.
      Car is fuel injected LT1.
      I assumed overfilling the oil would be the temporary solution. Last thing I want is to tear up my motor out of state, I don't/won't ever trailer my car.
    9. #29
      Oct 2014
      Cañon City,CO
      I run stock 68 Mustang Buckets ,for now, I use a 3" Race latch lap belt over a replacement 3 pt type belt. I pull the race belt as tight as I can get it. Before I stage you will see me give that belt several good tugs!
    10. #30
      Feb 2016
      I had a couple other questions that crossed my mind if I was to trailer the car there is there an area to unload it at or do you drive it all the way up to the pits? Then as far as refueling work is there any protocols regarding that? Then lastly for repairs if something that isn't to tough to repair can you do that up in the pits and what would you suggest to bring for tools? and can you keep them in your spot? Thanks again for the help!
    11. #31
      Nov 2012
      They provide a secure spot for unloading and you can leave your trailer overnight. Some hotels may have an area for this too. Fill up with gas before you enter. You won't be using enough to worry about running out. Yes, you can repair in the pits and you can leave to tools where you're parked in a tub or something. They won't let you run if your car is leaking so bring stuff to repair hoses like clamps, screw drivers, maybe and adjustable wrench.
      I see more people adjusting shocks and tire pressure than doing repairs. If your car is in good driving condition, you won't have much to worry about.
      _______________
      1969 Camaro
      1966 Skylark
      1964 Lemans
      1960 Biscayne
      Steve
    12. #32
      Apr 2017
      Lindenhurst, NY
      You ran great there man. I was watching lol.
