      Connecticut
      One more tire question!!
      Before I place my order I just wanted a couple more sets of eyes. These tires are going on my street driver 68 camaro full ride tech level 2 suspension with tru turn. 18x8.5 front wheels and 18x10.5 rear wheels. I wanted a little more side wall to help with the crappy new england roads. This is what I am about ready to purchase do these sizes look good?
      245/40ZR18
      (97Y) XL
      300 AA A 1,609 lbs. 50 psi 10/32" 24 lbs. 8-9.5" 8.5" 9.8" 9" 25.7" 809 US,FR
      295/35ZR18
      (103Y) XL
      300 AA A 1,929 lbs. 50 psi 10/32" 28 lbs. 10-11.5" 10.5" 11.9" 10.8" 26.1" 797 FR
      Paul Krol
      1968 Camaro
      Dec 2016
      delaware
      Looking at similar sizes except rear your going bigger ,Im not 100% But i was told 285 rear is tight onmy 1971 chevelle ,partly because of a lowered suspension good luk i like your size rear that is what i want
      Aug 2016
      Tampa FL
      Unless you have mini tubs, Your rear wheel choice is too wide. 275 35 18 is largest most can fit in standard wheel well for 67 / 68 . Even then you will want to roll the inner edge of fender for rough roads, or risk loosing chunks of tire when you hit a bump. Inner well to fender lip is normally about 11.25 inches. 69 owners get an additional 1.5 inch. Your 10.5 wide rear wheels will be tight.
      Oct 2005
      Bay Area CA
      I run 19x10 & 18x8.5 wheels on my non mini tubbed 68. I opted for a 245/40/18 front. Zero issues. As far as rear I've ran 295/30/19 pilot super sports in the past and didn't have any clearance issues however 295 was the limit. I got a deal on some Pirelli P Zeros and now run a 285/30/19. They fit perfectly in the wheels and only weigh 26lbs per tire. I believe you are should be good to go with the 295/35/18 however if you want to be safe (every car is a little deferent) a 285/35/18 would be an option.
      1968 Restomod FireBird • Twin Borg Warner EFR Turbocharged LS3 • T56 Magnum • Ford 9”• Modern Sub-Frame & Suspension • C7 Seats • 24 Pistons • Forgelines
