    Results 1 to 20 of 24
      Feb 2003
      SoCal
      Crazy idea in my head....MIRRORS!!
      Wasn't quite sure where to put this if not mods please move to correct place if you have any questions please ask I will be happy to share!! Keep in mind these were made with regualr hand tools I have ordered the correct tools to make them with precision cuts and whatnot!
      I know this applies to the bullet mirrors some of you guys are using on you 1st gen camaro/firebird or any other thing you want to install these on......Hope it helps some, I am about to start my build on my PT 83 Cutlass cruiser wagon (think Malibu wagon) and I wanted to incorporate some of the ideas that have been swirling around in my head that I wanted to try I scrounged up some pennies and bought the supplies needed to make my turn signal mirrors like on the newer cars..... all in all it took about an hour to put what I had in my head to the mirror!
      They are brighter than I expected actually, I still have to mount them permanently but you get the idea. I also only used 3 led's I am going to remake the lens to hold 4.
      Jul 2013
      Gilbert, AZ
      Dang, you beat me to it! I was thinking of doing the same thing. Looks good!
      Feb 2003
      SoCal
      Quote Originally Posted by CampbellshotrodsAZ View Post
      Thanks it was pretty easy once I had the how sorted out lol!
      Appleton WI
      Cool!
      Jim
      1968 Camaro --502HO, ATI 10" TreeMaster, Hughes TH400 with Gear Vendor's OD, Moser 12-bolt, RideTech StrongArms and MuscleBar, Chris Alston G-bar rear suspension, 2 1/8" by 4" Lemon's Headers through 3" Pypes X-pipe and Hooker AeroChambers.
      Nov 2007
      Windsor, Ontario
      Any updates on this
      Feb 2003
      SoCal
      Yes my new LED's will be here tomorrow and I also remade the insert and I polished it as well, also the insert has been set into the mirror as well I will HOPEFULLY have a full working unit by Friday and I will post pics during the day/night and standing in front of the car as well as behind and video!
      Looking forward to seeing these. Great idea.
      Feb 2003
      SoCal
      Finally Finished
      Nov 2007
      Windsor, Ontario
      Very cool idea
      Feb 2003
      SoCal
      Quote Originally Posted by AB69Z View Post
      Very cool idea
      Thanks!
      Jun 2008
      Acworth, GA
      This is an awesome idea, and great execution! Can you tell me what the LEDs are in and how did you get the shape to match the curve of the mirror? Did you set the LEDs in some sort of clear resin and make a cast? I have a similar idea on putting LEDs somewhere (not a mirror) and am trying to figure out how to get the shape and thickness to fill the gap. I understand if you don't want to give away any secrets, though.
      Feb 2003
      SoCal
      Quote Originally Posted by gardnerme View Post
      LOL Nooooo I will definitely share....if you share your idea as well for us all!!!
      I am going to make an actual execution video and post !!
      Jun 2008
      Acworth, GA
      Quote Originally Posted by Radlark View Post
      Sure - I will share! It is not like I expect to be the first one to actually implement this as slowly as I am progressing. :-)
      I have a 1967 Camaro I don't plan to run the front bumper on. There are four brackets that hold the bumper on the car, and the two outer brackets are sandwiched between the front fender and the lower fender extension. When you don't install the front bumper, you are left with a gap between these panels that needs to be fill. One way of doing that is to add metal to the bottom flange of the front fender, but I have been wondering how hard it would be to install some LEDs in this gap to act as a side marker light/additional turn indicator. What you did with the mirror is dangerously close to what I have in mid, it is just a different profile and probably thickness.
      The 68 Camaros have a side marker ight on the side already, but some people fill those in so this could work on those cars as well.
      I could not get a good picture of my car because it is in the garage and it surrounded by stuff. So, I cheated and went to the internet to find a pic that I could show the area I am talking about. I apologize if this image is somebody's that they want me to remove. If so, let me know and I will do so. Otherwise I have circled the area on the phot below.
      I look forward to your video! It might give me some serious insight if I could do something similar.
      Feb 2003
      SoCal
      Very cool!! That would look trick! I will make the video probably tomorrow morning and post!
      The mirror came out nice !
      Aug 2008
      jacksonville,fl
      I've thought about this sort of project before, just never had time to get around to it. On my 2016 Camaro nose el camino project, I decided to just put side marker / signal lights into my upper fender vents, which I have seen done factory in some vehicles.
      For my rear sidemarkers to go along with my swapped 2016 vette rear, I may want to make something superbrite, slim & flush, so it may save me a little trouble to see a reasonably easy way someone else has done such as item in a hopefully reliable enough sort of fashion. By reliable enough, I also mean quality of light supplier, which has been my problem with some led projects in the past.
      Feb 2003
      SoCal
      The "how to video as promised!!
      May 2010
      kitchener,Ontario,Canada
      Very cool...now if we can find out how to make them power mirrors
      Ryan Austin
      On Instagram ryanaustinss70
      Feb 2003
      SoCal
      LOL ....funny you should mention that.....wait until you see what else I have up my sleeve!!!
      May 2010
      Beautiful.... I think it was Kevin Oeste who's shop made some power but he never told us how yet ....I want some with carbon mirrors from Anvil... otherwise I'm going C5 mirrors
      Ryan Austin
