    Results 1 to 17 of 17
      Oct 2008
      Welding subframe to unibody?
      Tried searching but couldn't find anything, anything negative about making the front subframe a permanent part of the chassis? I figure with subframe connectors and a through the firewall roll cage the subframe isn't coming out anyhow so why not just eliminate the body mounts and make it a solid structure all around. Is there anything inherently flawed with my thinking? I never see a need to remove it anyhow after the connectors and cage are welded to it. So, any good reasons not to?
