      Jan 2017
      Looking for wisdom
      Alright here it goes. Would you rather run these cpp arms upper and lower( http://www.classicperform.com/Store/.../6472TCA-K.htm ) with the AFX spindle.
      Or my other thoughts were going with a full ridetech setup. Either way, I will be using ridetech single adjustable coilovers. I was given a set of those cpp upper and lower arms(new) and am just trying to figure things out. Car will mostly be a street cruiser, but I hope to get into auto X more. Its for a 1966 chevelle.
      Will the cpp arms with the AFX spindle change the geometry better then say a drop spindle and the ridetech arms?
      Mountain Springs, Texas
      AFX spindle can save you money on brakes because you can run C5/C6 brakes. If you are going ridetech you should consider adding the Tru-turn to improve the geometry. Not sure it is comparable to AFX spindle otherwise.
      Not sure I would classify this as wisdom....
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Sep 2015
      looking for info too
