    Page 2 of 2 FirstFirst 1 2
    Results 21 to 27 of 27
    1. #21
      Dec 2010
      Fredericksburg, VA.
      I have contemplated using a relay on the main 12v cable but instead I installed a 250amp circuit breaker back in the trunk next to the battery so that it will trip if the cable shorts. I also have a master disconnect switch mounted in the trunk so I can kill power when the car is being stored.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
    2. #22
      Chit-ca-go
      I too, am running a breaker in the trunk. No solenoid. My G8 has a constant live feed from the trunk as well. The only reason I didn't initially go with the bulk head is that I didn't have one on hand but did have the pass through linked above.
      1971 Firebird
      2017 Slipstream SS
    3. #23
      Ontario, Canada
      Quote Originally Posted by 70 Chevelle View Post
      I picked up one of these at a local electrical supply store. It eliminated two connections at the fire wall that you would have with a bulkhead connector. It is water tight and holds the cable securely.
      Working well so far.
      Ken
      My other car is a Vega.
    4. #24
      May 2016
      Pilot Hill, Ca.
      I didn't see it mentioned but I used the Ron Francis bulk head fitting. Didn't want to put that big of a hole in the firewall after all the time spent filling holes, but everything I looked at needed a big ass hole.
      Life's a journey not a destination, So let's all live Life in the Fast Lane.
    5. #25
      Oct 2008
      Kingsland, GA
      Quote Originally Posted by Richard454 View Post
      Here you go- a neat solution-cost maybe $5 at your local pull-a-part
      Not only to hook up your starter but also a terminal block for a couple other connections-
      Mounted on the firewall- look at the mid 90's BMWs - the big ones 5 & 7 series
      Cover on-
      Have a part number?
    6. #26
      Jul 2020
      Does any have some more information on the BMW part in the previous post?
      After a couple of days of Googling I've had absolutely no luck identifying this BMW part.
      Year. Model. Part number. Anything more than just a photo might help.
      Anyone?
      Thanks.
      Chuff.
    7. #27
      Feb 2013
      South Carolina
      Here's the E46 firewall pass through. That should get you started.
      https://www.ecstuning.com/b-genuine-...xoCBFkQAvD_BwE
      https://www.ecstuning.com/b-genuine-...RoCFBkQAvD_BwE
      Quote Originally Posted by Chuff View Post
      Anyone?
      Thanks.
      Chuff.
