Results 1 to 20 of 47
Thread: 69 Camaro subframe
- Dec 2016
- 71
69 Camaro subframe
Long time reader, first time poster. I have some questions regarding the build up of my 69 Camaro subframe, a topic I know has been best to death but there are still some questions I have after reading this forum for countless hours.
First some background. The car is a 69 Camaro currently in the sheetmetal work stage but it's time to start mocking up suspension components before finishing off the bottom of the car, which leads me here. I have done full floor, trunk, inner and outer rockers, full quarters, mini tubs, outer wheel houses, toe kicks, rear inner valance, tail light panel, decklid, roof structure and roof panel, tourque boxes, door skins, the list goes on....
plans for the car are to be pro touring, coil overs all around, 4 link, ls air conditioning etc...its use will be more towards the "touring" side as I plan to drive it A LOT. Things like the power tour, drive to large scale shows such as good guys, super Chevy and the like. Now once I get there and there happens to be some road course, auto x, braking challenges etc I would like to participate and have fun with the chance of performing well.
i have found myself researching the abundant amount of info about aftermarket subframes vs building up the stock sub. My stock sub mounts are rusted but I'm plenty capable of repairing so that's not an issue.
Reading about stock subs is I mainly find myself hung up on the spindles. I understand with all the control arms of the major manufactures that they offer corrected geometry to improve camber curve, as well as some like global west adding in lots of caster. Which they all seem to be equally competitive with one another
spindles on the other hand are more of a mystery. I understand the goal with a spindle is to raise the upper ball joint location, also to help camber curve, as well as relocating the steering attatchment to reduce bump steer. My past research around this forum shows the ATS afx spindles are the most recommended. They are also the most expensive.
My question lies with, what other spindles are out there? They can't be the only ones offering such improvements. I see pictures of aftermarket subs running spindles the are not those aluminum ats units housing a c5 bearing. So what spindles are they? For my use, the increased cost in an aluminum spindle to save weight (not a huge concern for me) or the cost of running a sealded bearing (also doesn't interest me much) doesn't add up to me needing to spend $1300 on some spindles. So what are my options?
as far as overall cost of building up a stock sub, I only end up a couple hundred short of have a complete heidts or tci unit. Would these subs offer the handling and performance I am after. Dse art Morrison etc are just not in the cards. What are your opinions on these two subs?
ultimatley if it handles and stops like a modern high performance car, like my 09 Srt8 challenger for example, mission accomplished
