      Jun 2015
      Columbia, SC
      Question on selecting a converter.
      I have a TH350 behind a Pontiac 400 with a cam that Comp recommends a mild converter to pair with. By "mild" they mean what? 2000 RPM? I also see choices for "sprag" and "spragless" converters and I can't get any info clear enough to help me make a choice. I'm also looking at 3.42 rear gears over my stock 2.73 if that helps.
      Appleton WI
      What RPM range does Comp list for this cam and what rear tire diameter are you planning to run?
      Jim
      1968 Camaro --502HO, ATI 10" TreeMaster, Hughes TH400 with Gear Vendor's OD, Moser 12-bolt, RideTech StrongArms and MuscleBar, Chris Alston G-bar rear suspension, 2 1/8" by 4" Lemon's Headers through 3" Pypes X-pipe and Hooker AeroChambers.
      Sep 2015
      Rockvale TN
      If you want clear information based on fact contact any convertor manufacturer of your choosing...they will ask you all the pertinent questions and supply you with what you actually need.
      Feb 2011
      General rule of thumb from the converter people is 300 rpm higher than the bottom of your cam's power range. So, if you have a 2500-5500 rpm rated cam, then 2800 rpm stall. This is a little tough to pick unless you've had it dyno'd. MOST of the cams advertised are rated for the middle engine in the range -- meaning if it says Pontiac 326-455 - 2500-5500 rpm, then you could expect that power range out of a 400. Same cam in a 326 will range from maybe 3000-6000, in a 455 it might make power from 2000-5000.
      70 GTO - Alum 5.3/4L80e, 7875
      17 GT350
      Feb 2016
      Lawrenceville, IL
      Quote Originally Posted by Pancho79 View Post
      If you need some help getting one just let me know. I have a converter tech sheet I'll send you that will give me all the info we need to get you set up with the correct converter. you can email me [email protected] and I'll shoot you back the tech sheet. Thanks!
      visit us on the web at www.bowlertransmissions.com
      Jun 2015
      Columbia, SC
      *Update* Got one chosen. Thank's, Craig, for all the help!
