- Dec 2009
- Wauconda, Illinios
- 1
1968 Camaro RS Pro Touring Project
Car has been completely stripped down every last bolt and back new. Car has everything installed in New Full Heidt's Pro Touring Chassis Power Coated. Body work almost complete. Pick your engine, trans and paint color and have this project done for spring. Original RS manual set up. Owned this car on and off last 30 years. Been building this car for last 8 years. My goal was fun driver/ autocross track days build. Over 34K invested. Asking 22K. OBO
Further question contact me. Car located in Wauconda, IL
Erik: 847-910-8537
Email: [email protected]
http://chicago.craigslist.org/nwc/cto/5897257951.html
Everything New never used but installed listed below:
Chassis. Full Heidt's Pro Touring complete front sub frame. Included 12" wildwood 4 piston 2 piece slotted and drilled rotors, power rack, trans support, sub frame connectors, drive shaft loop. Everything powder coated black with satin clear powder coat finish. Heidt's full rear 4 link suspension, panhard bar, upgraded sway bar. Rear brakes wildwood 4 piston slotted and drilled, custom parking brake, all four corners AFCO fully adjustable coilovers satin finish chrome springs. Rear end is 8.5 10 bolt 3:73 Posi. With new upgraded Moser c-clip axles, Moser aluminum diff. cover.
Body is alignment and blocked and sanded first stage done. Is currently primed with a spray type finish ready for second stage of blocking and sanding. Everything new and replaced already. Door skins, front floor skins, rear inner and outer wheel housings, full quarter panels, trunk lid, front fenders, inner front wheel wells, valance upper and lower, radiator support. Underneath everything was sanded and wire machined, primed and painted with Eastwood primer and paint. Trunk has been sanded primed and finished with trunk paint and new trunk springs. New Stainless gas tank with sending unit and have a second new steel gas tank and sending unit.
Everything else new and installed. Ididit Blk powder coated tilt steering colum, borgeson U joints, rod end bearing, Lecarra mark 9 steering wheel, billet steering wheel adaptor, Lokar gas pedal, All installed American Autowire complete new full wiring harness, Wilwood master cylinder and proportion adjustable valve. Inline-tube brake lines installed with stainless flex brake lines and bleed. Complete 6 gauge panel with Phantom gauges. All electric expect speedo.
Wheels- Rocket Booster 18x8 front with 245/40/18 nitto NT05 tires. 18x9 rear with 275/40/18 Nitto NT05 tires. New tail lite bezels. Interior, dynamat sound mat under new carpet, new headliner, rear seat redone, dash bezel, mirror, pillar pads, heater core, pedals, firewall pad, arm pads, new door glass, new Corbeau A4 Racing reclining seats with double lock adjustable seat bracket's.
Know I'm missing other items installed and included. As you know I have a lot of time and money in this project. Steve Nick Restorations has been doing the bodywork. Have a new balanced 383 short block for the build at additional price if interested with heads, intake cam, lifter, rockers.
Further question contact me. Thanks, Erik
Selling full project car only. Not parting out. No trades.
Asking $22K OBO
