- Aug 2004
- Ramona, CA
- 66
TKO600 Transmission Swap Progress
I'm the the process of swapping a Tremec TKO600 5-speed for my TH-400 automatic.
Pedals are swapped:
I just finished fabricating the transmission crossmember today. I started with the reproduction TH-400 crossmember that was in the car, and wound up with this:
I'll be using a Keisler hydraulic throwout bearing setup, a McLeod aluminum flywheel and a custom 12" single disc clutch setup (also from McLeod). At the moment none of these parts have arrived yet.
Still to do are to clean up some of the underdash wiring, cut the floor for the manual transmission, order a driveshaft, and index in the bellhousing. I'm hoping to have the project done in early October, and try it out at the track (road course) in early November.
09-19-2004 #2lookin nice and clean!
:3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
09-19-2004 #3Are you going to SOWS? (enjoyed your video clips, BTW). I'll be there if I can finish preparing my car in time.
Originally Posted by JonB69FB
Very nice work!
09-19-2004 #4
- Aug 2004
- Ramona, CA
- 66
That's the plan! The Speed Ventures event is on the 12th.
09-19-2004 #5Jon, it looks great! I'll be anxious to hear how you like it.
Brian D
Snotty Bimmer driver.
