      Jan 2014
      NY
      T56 alignment question
      read all the how to threads and the only question I have is does the dial indicator need to be center on the crank shaft?. if so any tips, thanks AJ
      parts are T56 magnum, LS 1 bellhousing, mating to sbc.
      Feb 2016
      Texas
      No, it does not need to be centered. As you rotate the crank the dial indicator will sweep 360* and you are looking for the runout measurement so it's all relative. Depending upon where you anchor the dial indicator you'll just be sweeping a circle with a given radius, move the indicator and the sweep radius changes. Before you check the runout, make sure to first check that the bellhousing (BH) is parallel to the block. I shimmed my BH to adjust the runout first and subsequently decided I should also check if the parallel measurement was within spec which it was not. Once I adjusted the parallel by shimming it I had to readjust the runout with the offset dowels.
      Nebraska
      What is the best way to check if the block and BH are parallel? Thanks Lonnie
