    Results 1 to 1 of 1
      Dec 2015
      incoming 1966 fastback
      66 Mustang Fastback CarEngine Information
      Engine Ford 427 cu.in. - stroked 351W small block (4.040 Bore 4.170 Stroke 6.250 rod length)
      Engine has less than 1000 all street driven miles
      Compression Ratio 10.31
      Engine Flywheel HP 540 hp 5300 rpm 560 ft-lbs torque 4300 rpm (using a custom Holley 750HP carb)
      Ignition MSD 6AL-2 with MSD Pro Billet Mechanical Advance Distributor (22 Initial 34 Total timing)
      NGK FR-5 spark plugs
      Intake Manifold Edelbrock Performer RPM Dual Plane that has been ported by Bryce Mulvey at Dr. Js Performance (316 cfm average runner flow). The center divider in the intake is notched.
      Intake Manifold Bolt Pattern Single 4150
      Cylinder Heads Pro Comp (Edelbrock Victor Jr. Clone) CNC Ported by Mark Jeffrey at Trans Am Racing Engines 5-angle valve job
      1.7 rockers
      Intake Valve Diameter 2.08
      Exhaust Valve Diameter 1.6
      Intake Port Volume 225 cc
      Exhaust Port Volume 74 cc
      Combustion Chamber 68 cc
      Flow Data 308.2 cfm at 0.60" lift 28" H2O 311.4 cfm at 0.625" lift 28" H2O and 316.1 cfm at 0.650" 28" H2O
      Camshaft Bullet Cams Hydraulic Roller
      Camshaft - Intake Duration .050 243 (299 lash duration)
      Camshaft - Exhaust Duration .050 250 (306 lash duration)
      Camshaft - Intake Gross Valve Lift 0.625 using 1.7 rockers
      Camshaft - Exhaust Gross Valve Lift 0.625 using 1.7 rockers
      Lobe Separation 109*
      Intake Lobe Centerline 106*
      Fuel Type Pump Gas 91 to 93 octane
      fuel pump Mechanical
      Fuel Pump GPH rating 120
      Fuel Pressure at Idle 6 12 to 7 psi (adjusted by regulator)
      Oil Pump Carter StreetStrip high volume
      Transmission Type Manual 4-Speed Top Loader
      Rear End Currie 9 Inch Ford with TSD (limited slip) Differential 31 spline axels Ratio 3.251
      Suspension Car was featured on the front cover of the 2004 Total Control Products (TCP) catalog. Total Control Products Front Suspension with Rack & Pinion Steering Total Control Products Full Sub Frame Connector System Total Control Products Shock Tower Brace System Maier Racing rear leaf springs and panhard bar 4-wheel disk brakes 3 aluminum driveshaft
      Wheels & Tires American Racing Torque Thrust II 17 x 8 Yokagawa 235-45-ZR17 25.3" diameter tires
      Mufflers SpinTech Pro Shoot Out Race Series 2 12"
      Headers Hooker Super Comp 6208 1 34" primaries 3" collector
      Additional Cylinder Head Flow Data
      Intake Exhaust
      .100 68 51
      .200 142 110
      .300 210 175
      .400 254 207
      .500 288 218
      .600 308 221
      .700 322 225
      Additional Intake Manifold Flow Data
      Runner CSA exit 2.63 sq "
      Runner CSA Plenum Entry 3.42 sq " total
      Flow Numbers
      Tested at 28" with 4510 Carb simulator (cylinder heads not attached)
      Runner Flow
      1 302 cfm
      2 330 cfm
      3 328 cfm
      4 310 cfm
      5 315 cfm
      6 312 cfm
      7 328 cfm
      8 309 cfm
      Additional Engine Build Parts Information
      351W block
      Complete bore package
      Super street & strip stroker kit
      Crank shaft mild knife edge 4340 indexed oil holes & re- heat treated
      Main girdle w studs
      Total seal rings
      Thermal coat je pistons
      Trans am racing cnc heads
      Thermal coat valves
      Gaskets
      New front cover
      Fel-pro head gaskets
      Edelbrock performer rpm intake ceramic coated
      Stage ii port intake
      Gasket match intake
      Blp custom built holley 750hp)
      Arp head bolts
      Arp cam bolt
      Arp crank bolt
      Arp oil pump shaft
      HV adjustable oil pump
      Rrp ss bolt kit
      Aluminum hv water pump
      Custom billet hyd. Roller cam by bullet cams
      Skorpion billet roller rockers- 1.7=.651
      Bullet hyd. Roller short travel lifters
      Beehive springs
      Probe rocker stud girdles
      Comp push rods
      Comp retro kit
      Msd dist. & 6Al-2 ignition box 6421
      Taylor 8mm wires
      Ngk fr-5 plugs)
      Carter hp fuel pump
      Sfi balancer
      Road race front sump pan
      Front sump pick up tube
      High tq mini starter
      2015 Porsche Macan Turbo (white)
      2015 Porsche 991 Turbo S (agate grey)
      1996 Porsche 993 Turbo (guards red)
      1970 Dodge Challenger (B5 blue)
      1968 Porsche 911 (sand beige)
      1967 Vette (elkhart blue)
      1966 Pontiac GTO (light blue)
      1966 Fastback (black)
