    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 56
      Nov 2010
      Changing the game with headlights ... Can it be done??
      https://www.amazon.com/Daymaker-Proj...ound+headlight
      I would love to see these in my camaro... you guys thinks it's possible.. without too much of headache
      68 Camaro RS twin turbo
      Slow Lifted Jeep No TURBO :(
      Randal F
      Seems like mostly plug-n-play, no?
      Be interesting to experiment with for that price. On my 66 Nova I went with a setup from Delta lights that is not DOT approved but I like them. I have never been pulled over by a cop and they look similar to original lights.
      Tom
      May 2016
      Bay Area
      I also went with an LED headlight from Delta for my 66 Nova and I love em. worth every penny imo.
      link: http://www.classicindustries.com/pro...ts/153108.html
      Quote Originally Posted by Fuelie Nova View Post
      Tom
      Jun 2012
      I have really good luck with the trucklite.
      Get what you pay for in stuff like this.
      86 Mustang
      454 LS3 Mast 4500 intake FTI cam Holley EFI Drag radials and pump gas 9.24 143.73
      79 Z28 Bonspeed GT-B DSE front and rear Z51 Brakes 5.3 Holley EFI Vintage Air
      Mission Viejo, CA
      I'm pretty sure that is a Chinese knock-off version of the JW Speaker 8700 EVO headlight. Harley sells the JW version as The Daymaker. As expected, the China part has very poor quality compared to the real ones from JW Speaker. The Chinese versions have only 78 lux rating @25 feet, compared to over 500 lux on the JW Speaker version. You can read up on these and many others on youtube here. This is the review of the real Daymaker. https://www.youtube.com/watch?v=YQQoptdOlNw
      JW Speaker now has the 8700 EVO 2 which replaces the original 8700. The 8700 EVO 2 is the newest version and received excellent reviews on the Headlight Revolution site. These are not cheap. They retail around $325.00 each, but they are very high performing lights and are DOT certified. I have been doing a lot of research on headlights recently for my project. Hope this helps you.
      1973 Hurst Edition Pontiac Grand Am: 430 CI of ERL built LS7, Tremec Magnum T-56 6-speed, Global West / Speedtech Suspension, Custom rear coil-over suspension, QA1 double adjustable shocks, Wilwood 6/4 piston disc brakes, Modulare C1 19" concave wheels. Shooting for 625 HP and 20 MPG!
      Jun 2006
      Quote Originally Posted by Later-A-body View Post
      The Evo 2 appears to be a good quality reliable LED headlight. If you are buying these because (1) you like the way the look, or (2) you like the low current draw, then this is probably your best bet. I would not mess with any of the knock-off junk, I get enough of the local rice crowd and their crap lights shining in my eyes when they approach.
      If you want MORE effective and lower cost, I have the "Cibie H4 headlamps" which I purchased from Daniel Stern lighting. Housings are $79 each and the bulbs I bought were about $25 each. The "downside" is very few people will notice they are not OEM lamps, they are glass housings and look similar to stock sealed beams. So if you are all about looks, then they are not for you. If you are about lighting a path 1/2 mile down the road on high beam then they are. They put more light down the road than any HID I have seen. I use the OSRAM 85/80 bulbs. You absolutely MUST run relays with these lights to get the most out of them and not fry your switch or harness. Link: http://www.danielsternlighting.com/p.../products.html
      Nov 2010
      Quote Originally Posted by 68Cuda440 View Post
      thanks for the info! it might happen down the line... but not now because of funds being moved due to a damaged engine :(
      - - - Updated - - -
      I would assume so... I mean they would be cool to run and the car a different look
      Randal F
      Nov 2010
      went with these after seeing.. they go in with no mods
      Truck-Lite 27270C
      Thanks guys!
      Randal F
      Nov 2010
      Yea I know about Jw speaker, I have them in my wrangler and feel like i can see for miles and feel bad for anybody driving in front of me
      Randal F
      Mission Viejo, CA
      Here is the review of the Chinese knock-off version of the JW Speaker headlight. https://www.youtube.com/watch?v=fzVICq2ggUk
      Newbury Park, CA
      I've had the H4 Hella glass and the JW Speaker units in the Camaro. It's no comparison, the JW''s are better in every regard.
      The lower bulb life of the high-power H4 is a drawback as well plus the power requirement is a small fraction for the JW. No relays needed.
      WA
      I bought the Jw evo 2s for my 69. Looking for good info from people that got them to fit right in the housing and resizing the trim ring. Any help is appreciated. Thanks! Amazing light output!
      Mar 2015
      Truck light 27270C. Love them on my 69. Have to alter my headlight housing still but still love them.
      2014 ZL1
      Do you have any pictures of the work you did for the truck lite to fit light bucket you can post? thanks
      Oct 2014
      DFW, Texas
      I had TruckLite LEDs in my Wrangler and they were a drop-and-go change. I sold them after I sold the Jeep, I have no plans on putting them in a 70's muscle car. I stuck one in my 'Cuda and it looked terrible..
      Jul 2013
      Gilbert, AZ
      I'd be curious what people want in custom lighting for their rides. Are the Trucklites good as is for everyone? Or are more features wanted? Like accent lighting, or turn signals, or improved beam pattern?
      Reason I ask... I'm not a Program Manager for Rigid Industries, our parent company is Trucklite. I'll be following lighting threads here more carefully, as we're investigating other opportunities greater than the lightbars that we're famous for. Things like headlights, and LED driving lights are on my radar.
      Sep 2011
      Southern Ontario
      Hi josh. I have trucklites in my 56 F100. My suggestions would be if you do look at adding accent lights or anything, try to have an option without. I think the beam pattern could be improved, and lastly, I imagine a lot of people installing these could use with the mating plug and crimp on the new terminals themselves. But I do like them a lot and have had quite a few people ask me about them and where to buy
      Jul 2013
      Gilbert, AZ
      Quote Originally Posted by Peter Mc Mahon View Post
      The beam can be improved, that I've learned. There is some extra "noise" in the beam. The crappy part, is that we (Rigid) had a 7" headlight with a better beam in the works before we got bought out by Trucklite. Then they felt no need for the other 7". I'll see if we can dust the cobwebs off that.
      Beach Park IL
      Quote Originally Posted by CampbellshotrodsAZ View Post
      Forgive me, anything is possible when you know nothing of what you are talking about. So on to my dumb question.
      Can we get 5 3/4" and 7" lights that don't look like spaceship landing lights? If you made LED T3 looking lights (that actually worked better than the best halogens) it would appeal to the resto and PT crowd......and because looks "stock" doesn't step on mothertrucklites toes.
      Sooooo, get that done, please.
      Donny
