      Nov 2012
      Sacramento, CA
      StopTech & Ron Sutton Launch New Pro-Touring Brake Packages at SEMA
      Major Announcement - New Brake Kits Debuting at SEMA
      I am Proud & Excited to Announce We’re Launching My New Line of Ron Sutton Race Technology Optimized Brakes designed & built in conjunction with the Leader in Road Racing Brakes, StopTech. These new kick ass brake packages I've designed, are for the ultimate triple duty Pro-Touring cars doing Autocross & Track Days as well as REAL Street driving! With me being involved, you know these are going to be awesome for Autocross & Track Days ... and they are. But the big deal ... the major difference ... is how well they perform on the street with brake pads made for the street.
      Why did I develop a new line of brakes?
      I have been frustrated with the braking systems available in the Pro-Touring world since I entered it. The calipers from the popular brands don’t have enough piston area to provide good braking force with street pads. To get the level of braking performance needed, people went to more aggressive & abrasive race pads. These race pads cost 2-3 times as much, wear out twice as quick, dust up the wheels horribly and as a bonus, they eat up expensive rotors 2-3 times as quick. Ugh!
      I'm not naive enough to think we can have a brake system that will be great on the street, autocross & road courses with a single pad compound. That’s not realistic, because …
      * Pad compounds engineered to work well for the street, can't handle the heat generated on road courses and don't provide good enough "cold bite" for optimum autocross needs.
      * Race pads that will handle the heat generated on road courses will dust up the wheels & wear out quickly.
      * Autocross pads that have good cold bite, will dust up & wear out quickly, and won't handle the heat of road courses.
      * When we ask our cars to do triple duty, we need different pads.
      But for Pete's sake, for the street, we want modern supercar level braking performance with a street pad. Where we can drive our toys on the street, enjoy long pad & rotor life, not dust up the wheels & squeal at every stop light. This simply requires more clamping force from the brake calipers when we run street compound pads and want Supercar level braking.
      The challenge was the calipers from these popular brands are not strong enough to increase the piston area ... without experiencing even more caliper flex & sponginess than they already do. If you're not familiar ... caliper flex means the driver is not getting the full braking force. A certain amount of the clamping force is lost to the flexing or "clam shelling" of the weak caliper body. You can feel it in the pedal too. As long as you don't have air in the lines, that "sponginess" the driver feels is caliper flex. The more the caliper flexes, the worse this condition is.
      So I decided to come up with better brake systems for our multi-purpose Pro-Touring cars that can win in Autocross, run fast & hard on big, fast road courses & drive well in everyday street driving. The key was finding out who offered the strongest calipers, with the least amount of caliper flex & the space to handle the increased piston sizes. For me, it came down to who had the best caliper that met my criteria.
      Enter an old friend from racing, Mark Cornwell. He came up through Formula car racing, had a career in Indy car racing working with the Andrettis. Then took an unknown brake company in the USA ... Brembo ... to dominating in NASCAR in the 90's & beyond. Today Mark runs the racing division of StopTech brakes, where StopTech has won a ton of road races, including Trans Am & GT championships. The StopTech calipers are strongest, most rigid, lowest flexing calipers … hands down. In equal comparison brake dyno tests ... same pad compounds, same line pressures, same rotors ... the StopTech calipers produced the highest brake torque & did so with the least caliper flex. Period.
      So the foundation was set for me to design a superior line of brakes for Pro-Touring Muscle Cars to be Triple-Duty killers. All I had to do was design kits to fit muscle car spindles & spec what I wanted in the calipers, pads & rotors.
      These StopTech Brakes from Ron Sutton Race Technology are a Game Changer!
      What Makes These Brakes Better?
      * The Most Rigid Calipers, Period.
      * Lower Inertia 14" Rotors (Only 16.2#)
      * Industry's Best Heat Dissipating AeroRotors®
      * Stonger Hubs & Bigger Hub Bearings
      * Street, Autocross, Track Day & Race Pads
      * Patented Removable Bridge for Easy Pad Swaps
      * Patented AeroHats® for Optimal Cooling Airflow to Rotors
      What is the Real World Difference on Track?
      * Shorter Stopping Distances
      * Better Brake Modulation & Release
      * Firmer Pedal Feel
      * Less Brake Fade
      What is the Real World Difference on the Street?
      * Firmer Pedal Feel
      * Significantly Less Brake Squeal
      * Longer Pad & Rotor Life = Less Expense
      * Substantially Less Wheel Dust Up & Wheel Cleaning
      Front Brake Applications Available
      • 1967-1969 Camaro & Firebird
      • 1964-1972 Chevelle, Malibu & SS
      • 1964-1972, GTO, Cutlass, Skylark & GS
      • 1962-1967 Chevy II
      • 1968-1974 Nova, Ventura, Apollo, Omega
      • 1964-1972 El Camino & GMC Sprint
      • 1969-1972 Gran Prix & Monte Carlo
      • All Cars with ridetech Spindles
      • All Cars with GM C5/C6 Spindles
      • All Cars with Speedtech/ATS Spindles
      • Art Morrison C6 Chassis & Frame Clips
      • Detroit Speed Front Frame Clips
      • Roadster Shop Chassis & Frame Clips
      • Ron Sutton Race Technology Spindles
      Rear Brake Applications Available
      • 9” Ford with Torino Ends
      • GM 12 Bolt Passenger Car C-Clip
      • GM 10 Bolt Passenger Car C-Clip
      • RSRT/Speedway Floater
      Available Caliper Colors:
      • Red or Black
      • Trophy (High End / Fully Machined / Gun Metal Anodize)
      Front Applications Coming Soon
      • 1970-1992 Camaro, Firebird & TA
      • 1978-1988 Monte Carlo, GP, Regal & Cutlass
      • 1978-1988 El Camino, Sprint & S10 Truck
      • 1973-1977 Chevelle, Monte Carlo & Cutlass
      • 1973-1977 LeMans, Gran Prix & Regal,
      • 1964-1973 Mustang, Cougar & Fairlane
      • 1964-1973 Falcon, Ranchero & Comet
      • 1964-1973 Torino, Montego & Cyclone
      • 1962-1972 Mopar A, B, C & E-Body
      • 1973-1976 Mopar A, B, C & E Body
      • 1964-1970 Chevy & GMC C10 Trucks
      • 1971-1980 Chevy & GMC C10 Trucks
      Rear Applications Coming Soon
      • Speedway Mod-Lite Floater w/Parking Brake
      • 9” Ford with Big Ford Ends
      • 8” & 9” Ford with Small Ford Ends
      • GM 10/12 Bolt BOP Non-C-Clip
      • GM 10/12 Bolt w/3.15” Bearing Non-C-Clip
      • Mopar 8-3/4” & Dana 60
      • GM 10/12 Bolt C10 Truck C-Clip
      • 8.8” Ford C-Clip
      Want to learn more?
      Come see me & the new brakes at the StopTech Brake Booth #22557 in Central Hall of SEMA, these days:
      * Tuesday, Nov 1st - All Day
      * Thursday, Nov 3rd - All Day
      * Friday, Nov 4th - All Day
      Or, contact me after SEMA:
      Email:
      [email protected]
      Phone: (916) 834-8051
      Name:  RSRT-StopTech Brochure - Front Cover - 1000pix.jpg
      Name:  RSRT-StopTech Brochure - Back Cover - 1000pix.jpg
      Jun 2009
      From Wasilla, AK. Now portland, OR
      https://youtu.be/0aRkIajAVyA
      check out 2:48 they talk about the brakes
      1970 Elcamino ls3/t56, ricks/vaporworx, sc&c afx ,forgeline zx3, kore3 z51/ls1
      1969 Camaro ls3/t56, ricks/vaporworx, ride-tech,forgeline ga3,
      2024 ford maverick
