      Jan 2016
      Detroit Speed firewall panel
      I'm trying to figure out the best and cleanest way to weld this panel in to smooth the firewall on a 67 Camaro. I've seen pics of the panels being spot welded every inch or so but never fully welded all the way around. The question is do I fully weld the panel in or just spot weld it every half inch all the way around before I bodywork it. Also has anyone used seam sealer smoothed out instead of bondo?
      Dec 2010
      Fredericksburg, VA.
      What do the instructions recommend?
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      Jan 2016
      Was a Craigslist buy, no instructions.
      Jun 2006
      Indianapolis,IN
      completely weld around the panel. Tig if you can. If your going to wire feed. small sections at a time cooling the weld with compressed air as you go.
      Mountain Springs, Texas
      Spot it every 1/2 inch and seal the rest with panel adhesive. I use 3M 8115.
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
