Results 1 to 15 of 15
Thread: Pro/Engineer
11-13-2005 #1
Pro/Engineer
Does Any one else here get the felling like they want to beat the crap out of there computer with a sledge hammer after trying to draw something with pro/e.
Brian Schein
11-13-2005 #2Never used pro/e but I hear its not user friendly.
I have always used Unigraphics. Can't wait for the ne NX4 to come out.Robert Braga
1969 Camaro LS2/T56 D1SC
www.automotivedesigneng.com
US Collision / Mortenson's Custom Touch / DPE Wheel / Tim Bruning / Columbia Parts Company
11-13-2005 #3Yep, Pro/E has somewhat of a nasty reputation, but a lot of guys love it. What problems are you having?
I can tell you that SolidWorks can be alittle fussy at times, but 99% of the time it's great. Personally, I wouldn't bother with anything else.-Matt
11-13-2005 #4
- Aug 2005
- Orlando, Florida
- 1
I use Pro-E everyday. Post your question and I will try to help you.
Jay
11-13-2005 #5I am having trouble doing a pattern of a rib about the center axis of a revolve. Everything sets up right but when you hit the check it comes up with one of those error boxes. I was told to create a new datum and group the rib with the Datum and try and patter that but I can’t get that to work ether. I guess I will just go talk to one of the grad students tomorrow and see if they can help. I think the program has a lot of potential to do grate things, but its almost like its so smart that it has no common sense or maybe that’s just the people who are writing the program. Plus if you do something wrong it just says that you are doing something wrong but doesn’t say what it is.
Brian Schein
11-14-2005 #6Brian,
I am assuming that you are selecting the axis and a default datum as your references when you create the inital rib. What you need to do is select your sketch plane and then for a reference plane you will need to create a plane on the fly. Create this plane by selecting the axis, and then a plane normal to your sketch plane. This plane must be an offset so that you will get an angle dimension on the new plane. Now sketch your rib and when you pattern the rib you will select the angle dimension from the new plane as the pattern dimension.
If you need any assistance give me a shout I am in the office from 8A-5P. 716-687-5214. I am a Mechanical Designer an I work on Pro/E 8 hours a day. And yes it can be very frustrating. Fortunately we have 15 guys working with Pro/E and we have been running with it for over 10 years and so if I get stuck on a problem 95% of the time someone else in house has seen it before. SolidWorks is much simpler in the few times I have used it, but at my work we can't accomplish the same models with SW as with Pro/E. We do allot of complex surfacing.R.J.
11-14-2005 #7success
Thanks for the help I finally got it to work. I am not sure where the create the datum on the fly command is. MY problem was I was not holding the control key when trying to reference the datum to offset from after I had selected the center axis to revolve through, hence I would get no angular dimension. Is there an easy way to group things rather that going trough Edit/Feature operations and using the group command from the menu.
Brian Schein
11-14-2005 #8
