    Results 1 to 18 of 18
      Jun 2010
      Deployed
      Straight line performance sucks...DSE
      Folks,
      Driving my car a lot, I have noticed straight line performance is bad. I have the DSE set-up (their stock coils) 335 rival s tires, 3.89 gears, t56 magnum...tru-trac
      Doesnt matter which gear I'm in, if I'm in the powerband of my engine and gun it, the car's rear kicks out. I can't even mash the gas without siding the rearend out.
      What at could be wrong? Do I need higher rate springs?
      1970 Camaro/DSE build
      Mar 2015
      Sounds like a good problem to have if you ask me lol
      2014 ZL1
      Mountain Springs, Texas
      Do you have adjustable shocks?
      Maybe you need some Ron Sutton secret sauce...
      Don
      1957 Buick Estate Wagon
      1959 Apache Fleetside
      Jun 2010
      Deployed
      Yes, I have their single adjustable
      Have you tried adjusting both the front and rear shocks?
      Don
      Oct 2015
      Binghamton, NY
      Are the rear wheels "square" with the front wheels ?
      Chit-ca-go
      What tire pressure are you running?
      1971 Firebird
      2017 Slipstream SS
      Jul 2016
      My Shelby GT500 had the same issue until I put on Rear adjustable upper and lower arms, panard bar and lower rate springs with double adjustable shocks. Now it powers from a stop straight as an arrow and the rear wont swing to the left like it did prior. My bet is the rear is slightly angled or the pinion angle is off making the rear kick over to one side. is it always the same direction?
      Beach Park IL
      How did this end? https://www.pro-touring.com/threads/...k+not+centered
      Did firestone give you a print out of the alignment? What was the thrust angle?
      Donny
      Beach Park IL
      530 at the flywheel or the tires? And VVV
      Donny
      Feb 2011
      dallas, tx
      Mine hooks hard. Doesn't kick out at all unless I'm going around a turn and mash it but it's a controlled kick out. Air pressure is 32 psi
      Central CA USA
      Does it always go to the same side?
      Check your end link bushings & forward mounts.
      Dec 2010
      Fredericksburg, VA.
      Like others have said, check the rear end and make sure it is square with the chassis. Also, a softer compression on the shocks will allow more weight transfer which in turn will plant the rear tires.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      May 2015
      Island Lake, IL
      Spinning 335 rival no matter which gear. Must be making some power there.
      3.89 is a pretty numerically high gear ratio. It is magnified in power if you're also using a wide ratio transmission. My questions out of curiosity would be what's the gear spread in your T56 and how much power are we talking?
      St George Utah
      Quote Originally Posted by F-Body International View Post
      about the same combo as my Nova (mine made 520 to the rear wheels) had but I was running 315 Falkens and it would burn them in 2nd gear but you could not get it to spin in 3rd and it would go poker straight!! it is all about the balance an corner weights
      Blake Foster
      www.speedtechperformance.com
      435-628-4300
      St. George Utah.
      it's always sunny here.
      Jun 2010
      Deployed
      The engine produces 530hp. It's the magnum with the .64 6th gear, it's not the one with the deep first and .50 6th
      Jun 2010
      Deployed
      It's at the crank, but breaks the tires loose very easily which is what's causing it to slide out.
      St George Utah
      you need to scale the car and set the corner weights.
      the preload is off and there is more weight on one side than the other so that side pushes harder an pushes the car sideways
      Blake Foster
      435-628-4300
      St. George Utah.
