      Aug 2016
      DSE Rear Sway Bar Options - 2nd gen Camaro
      Been Reading a ton of threads before I start my build on my 70 Camaro. Looking to do a full DSE subframe with single adjustable shocks, connectors, quadralink rear, and mini-tub. New LT4/T56 swap, 12 bolt Mosier rear. I noticed DSE has three different sway bar diameter options (3/4", 1", and 1-1/8"). First of all, is a sway bar beneficial or needed with this setup? Secondly, if so what size is appropriate? I plan to make it a great driver to hit the backroads in AZ and do some hard canyon runs through the desert. Maybe some autocross and a small amount of track time, but that will be very little of the driving I do with it. I've read in some older posts 8-10yrs old, that rear sway bars only cause more oversteer in the corners. Would love to hear about anyones experience with this set up.
      Josh
