    Page 1 of 3 1 2 3 LastLast
    Results 1 to 20 of 49
    Thread: C6 Brakes
      Tacoma, Washigton
      C6 Brakes
      I have heard from a source that the C6 Calipers that are coming out this month and rotors will mount up to the C5 brackets. thats 14 inch front and 13.6 rear which would be killer. I was wondering if they will fit my Z06 wheels 18x9.5 and 18x12 and I hope it will work or I might have to go to 19's or 20's. Anyone out there know any thing about this new setup and if they will work, Bluaddict.
      May 2002
      Northern California
      ahhh its close but workable. You might have to run a small spacer.
      Zo6 C6 thread
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      OK
      I would love to know more this as well. I have a complete C5 kit w/ C4 rotors, but if I could upgrade to 6 pistons vs. 2...oh that would be nice addition.
      Dec 2003
      lost
      A quote from the thread Vince linked to-
      I must say that I'm watching this mod very close. GM has a long rich history with warped rotors and if you ever owned a C3, you know this set up with warped rotors will pump air into your brake system.
      As more C6 Z06's hit the streets, we will see of these OEM rotors are as good as the C5 aftermarket rotors...
      Flame suit on!
      Some people need to leave the tech alone, warped rotors pump air into a sealed brake system huh?
      Mar 2003
      Boringville
      I have a set of these brakes already on order. I have spent some time over at that vette forum, some of the guys know something, but most of them don't...................
      Jun 2002
      Long Island, NY
      Quote Originally Posted by yody
      Who did you order them from, and what was the cost of everything?
      Apr 2003
      chbg, pa
      also wondering?
      Quote Originally Posted by dennis68
      A quote from the thread Vince linked to- Some people need to leave the tech alone, warped rotors pump air into a sealed brake system huh?
      Yes believe it or not the C3 4 piston brakes will pump air into the system if rotor runout is too large.
      Too large is over .010" I think. The seal design has a lip that will roll back and forth on small movements and actually pump air inbehind the seal.
      There are replacement O-ring seals that help that problem but they have their own problems.
      Remember the brakes were designed in the early 60's and never updated!
      Personally I run Wilwood SL4's on my C3..
      And yes Yodi is right, some of them over on CF know something many dont!
      Los Altos CA
      haha i love how 90% of those guys just thought they looked cool.
      but if they bolt right up to c5 hubs what about the afx spindle... hmm semi cheap huuuge brakes $1600 for the whole gettup dang!
      so maybe ill be getting 18s afterall....
      Dec 2003
      lost
      Quote Originally Posted by 427v8
      Maybe a few very rare cases of OE 30 year old calipers but I have worked on hundreds of C3 vettes over the years with a variety of brake problems and have never seen that. In fact any car with deteriorated lip seals could do the same thing under the right conditions.
      Also check that whole thread, a few of those guys have done their homework and you can put together a Wilwood setup for less money...of course it is far less blingy so I'm sure we don't care about that.
      Mar 2003
      Boringville
      I'm not giving away any secrets..........but the brakes still aren't released, and they will be more than $1,700. You can't put together a cheaper wilwood kit, as the Z06 brakes are about $1,800 front and rear. You will need minimal 18" wheels. But the problem is that they are very wide calipers and require wheels with spokes that are far away from the center of the wheel. I don't think many peoples wheels are going to work with these brakes, unless you run spacers.
      Problems with these Z06 brakes
      most wheels won't clear without spacers
      aluminum pistons transfer heat (opposed to SS pistons)
      brake pads are very expensive and aftermarkets aren't out yet, and they are very thin, which also transfers heat, also they get cheese grated by the cross drilled rotors
      both front and rear use 2 left hand rotors meaning both of the right rotors are going to be backwards and heat up faster than the left
      stock front rotors are 25ilbs!!!!!
      2 piece 14" rotors are only about 17-18 pounds but are about $800 for just the fronts
      stock pads SUCK. aftermarkets arent' out yet, but expect to pay at least $400 for front and rear.
      Good things
      6 piston front 4 piston rear monoblock calipers with multi piston pads(20 brake pads all together)
      14" front 13.5" rear rotors
      looks really cool..........lol
      I am buying just the calipers/rotors now, and getting aftermarket pads later. And also later will upgrade the front rotors to 2 piece rotors.
      Jun 2002
      Long Island, NY
      Good things
      Pretty much everything you just said is in the thread Vince linked to. Nice summary, though. Why can't you post where you bought them from? Send me a PM if you don't want to post it.
      Los Altos CA
      t
      wtf???
      i didnt read all the posts about theese but why on earth would they sell them with just left rotors?
      Mar 2003
      Boringville
      actually that info all isn't in that post. But if you do some searching over there all that info is from there. There are like 5 seperate posts about those brakes.
      Jun 2002
      Long Island, NY
      I've been keeping an eye on these brakes for a while now, so maybe I've read the info in multiple threads. All I would like to know is where you bought them. It's okay yody, don't worry -- you can still be the first on the block with them. These would be for my 4th gen, and since it's winter I wouldn't be purchasing them anytime soon, not to mention I get factory stuff at dealer cost. Appreciate the info, though.
      Mar 2003
      Boringville
      Quote Originally Posted by Ralph LoGrasso
      hmmmmmmmmmmmmmmmmm..........................
      Jun 2002
      Long Island, NY
      Thanks again!
      Mar 2003
      Boringville
      how much room between your rotor mounting face and the backside of the spokes of your wheels? also the spacing on your back caliper bracket won't be right either, you would most likely have to space out your bracket or caliper.
      Jun 2002
      Long Island, NY
      I've got about 5/8" at the smallest point (closest to center) to about 7/8" at the farthest. There is a lot of room there due to the design of my wheels. The spokes cup outwards. I'd need custom brackets either way.
      Mar 2003
      Boringville
      Not sure where your measurements are from, if that is from the caliper that might be enough room, if that is from the rotor face, that proabably isn't enough clearance, PM sent, you sore loser LOL
