    Results 1 to 20 of 25
      Ramona, Ca. San Diego area
      Speed hut gauges. Complete set.
      Dash fits 67-68 Camaro but gauges fit other makes and models.
      I bought these and never used them. I ordered them with-out the R and the speedhut logo on the bottom for a cleaner look.
      Black face with white numbers that light up blue at night and a red needle to see better with.
      The wiring is really simple. All plugs together
      All the gauges have lights that warn you when something is out of the normal operation range. You can set the light to come on when the oil pressure drops to low or gets to hi. That goes for all gauges
      The speedo I bought goes to 200mph and is GPS controlled. The little screen on the bottom has 0-60 times, 1/4 mile times, GPS time clock, elevation, compass direction, speed in LCD, peek speed recall, and turn signal with high beam indicator.
      8000 rpm Progressive Shift dial (3 super bright LEDs).
      Settable shift point. Peak RPM recall.
      All the sensors included with plug and play plug
      The plug in wires can be mounted in the dash or under for simple control changes to gauges.
      The really cool thing is all the lights connect to this little red and white wire with plugs and are all controlled with the little knob control. The GPS wire is pretty long to place anywhere you need.
      Paid over $1100 for these.
      I also have both the center gauge and the main gauge housing from classic industries. Paid over $300 for them. Had them painted black.
      Sold for $1.
      67 Camaro convertible (Jinx)
      Sep 2009
      Wow, this is exactly what I need! Too bad I am not further along with my build. I had this very set in my 76 T/A LS1 swap and they are great gauges! Free bump, unless you are looking to donate to my cause
      Thanks for the bump.. make an reasonable offer, you never know.
      Apr 2011
      Hanceville, AL
      PM and email sent.
      Still available. New price $900
      Jan 2011
      Brisbane, Qld, Australia
      Country Flag: Australia
      PM sent
      Replied to all.
      Sep 2012
      Separate the oil, water, fuel & volts?
      2 1/16th correct?
      I'd be interested in them. Without the gauge pod
      Aug 2014
      If you sell the ones he listed to Anthony I'd be interested in the speedo and tach
      Nov 2004
      Pickering,Canada
      What sizes are all the gauges?
      Steve
      2-1/16 small gauges
      3-3/8 larger gauges
      Nov 2004
      Pickering,Canada
      Ok thanks. Looking for 5" tach and speedo
      Steve
      Sep 2012
      Not willing to split them between me aaanyoo1
      Aug 2014
      Quote Originally Posted by Anthony k View Post
      I'm interested in the speedo and tach
      Who is going to buy the covans dash? I'm good with splitting up the gauges but I don't want to be left with the dash. Unless one of you will buy the dash and resell it later to recoup.
      Apr 2008
      Toronto
      Are these still available?
      Yes
      New lower price $850
      Had these sold with promise but didn't go through.
      Available again.
      Bump
