    Results 1 to 11 of 11
      Ramona, Ca. San Diego area
      F2 pro charger with extras.
      F2 pro charger transplant kit for my first generation camaro. LS engine. Comes with everything to bolt it on. Tubing will need to be custom made. Includes a race blow off valve, competition carb hat. I bought this kit and bolted the main bracket to my engine and didn't like the way it was designed so I redid the bracket to fit lower away from the hood and closer to the engine to clear the inner fender. The F2 is huge compared to the smaller series blowers. Now it fits really nice. This will save you hours of frustration. You can't tell anything was done. The head unit, hat, and brackets are all polished. I'm including a polished power steering pulley and pump so you can just bolt that on too. I'm going to include a new ATI super damper. You'll need to have this pinned to your crankshaft so the belt won't spin it. I' bought a second set of brackets if you want to modify them to your liking or powder coat to you favorite color. This set up comes with the cogs belt so it won't slip under boost. I have a couple sets of pulleys to make low boost around 12lbs. and the other set is around 22lbs. This will depend on what your heads flow and intake tubing restriction. Never used or oil added. Im including the oil too. I'm sure there is a few things I'm not remembering but you can ask.
      Price is $5000 for everything. Less shipping.
      I'm located in San Diego county.
Size:  196.7 KBName:  20160913_204339.jpg
Size:  179.4 KBName:  20160913_204153.jpg
      67 Camaro convertible (Jinx)
