      Oct 2015
      1968 Chevy II Nova
      Clean, straight Nova looking for a new home. Looking to get $18,500.
      Pics: https://drive.google.com/drive/folde...EtobTNKSWNqMUk
      Video: https://www.youtube.com/watch?v=o05E9kC6qGw
      Cliff Notes: ridetech Front Suspension, Unisteer Rack & Pinion, Hydro-Boost Brake System, Wilwood Front Brakes, New Hard Brake Lines (Front/Back), Comp Engineering SubFrame Connectors (Not Installed), Detroit Speed MiniTub Kit (Not installed)
      Engine
      The previous owner knew little to nothing about the engine other than it was a period correct (1968) block, but was not original, and that it at least had a cam and heads installed. It runs perfect, and sounds amazing.
      Edelbrock Performer Heads
      Long Tube Headers
      Dynomax Bullet Mufflers that end in turndowns near the rear wheels
      MSD Billet Distributor (New)
      MSD 6AL Box
      Transmission
      Muncie M20 4 Speed
      Hurst Shifter
      Ram Clutch
      Rear Differential
      Ford 9” Rear Housing (was told it was from a 1970’s LTD)
      Richmond 4.11 gears w/Full Spool
      Body
      Body is extremely straight, no dings or dents that I have been able to find. Underside of the body is all rust proofed and painted black. Frame is painted as well, and in fantastic shape.
      Paint
      Paint is in pretty great shape. When I first bought the car, I didn’t notice any defects or chips. After its first wash/wax/detail session I noticed a few ‘chips’ on the front fender and rear quarter panel. All in all, less than 6 imperfections that I can find. It’s a solid paint job, you have to be almost right next to it to see most of these chips.
      Suspension
      New Factory SubFrame – Painted Satin Black and welded top and bottom
      ridetech RQ Series Coilovers - http://www.ridetech.com/store/1968-1...djustable.html
      Ridetech StrongArms Lower Control Arms - http://www.ridetech.com/store/1968-1...ont-lower.html
      Ridetech StrongArms Upper Control Arms - http://www.ridetech.com/store/1968-1...ont-upper.html
      Ridetech 2” Lowered Spindles = http://www.ridetech.com/store/ridete...dles-pair.html
      Ridetech Musclebar (swaybar) - http://www.ridetech.com/store/1968-1...bar-front.html
      Competition Engineering SubFrame Connectors (Not installed)
      Detroit Speed Mini-Tub Kit (Not Installed) - https://www.detroitspeed.com/1968-19...-tub-kits.html
      Steering
      Unisteer Rack and Pinion Kit
      2 Knuckle Steering Shaft
      Flaming River Black Steering Tilt Column
      Brakes
      Bosch Hydro-Boost Unit
      New Master Cylinder
      Wilwood 12” Rotors in Front, 4 Piston Calipers
      New Hard Brake Lines Front/Rear
      New steel Braided Front Brake Lines
      Stock Replacement Manual Drums on Rear
      Rear drums just replaced last year by previous owner
      Wheels
      Weld 5 Star Racing Wheels - http://www.jegs.com/p/Weld-Racing/We...46350/10002/-1
      4” Wheel up front
      8” Wheel in Back
      Interior
      In very good shape, all door panels, headliner, rear seats and trim are in great shape.
      Fixed back racing bucket seats
      New Carpet
      Misc.
      New Fuel Tank
      New Fuel Sender
      New AED 750 Carb
      4” Cowl Hood
      New optima red top battery
      Oct 2015
      Forgot to include this in the post above, I am located in Mechanicsville, MD 20659.
