Thread: Holley HP efi LS1 running issues
I have a 2002 6.0 Ls 24 reluctor wheel. i installed the Holley HP efi and it doesnt run right. car fires up but will some times backfire out the exhaust. currently idles at 800 rpm's and sounds pretty rough. the headers on the passenger side are noticeably hotter than the left side. plugs on the right side are completely black and the left side plugs are very clean. lots of black smoke out of the tailpipes too. the motor is stock. i have checked everything (i think). all connections are made, havent seen vacuum leaks. the software enters learn mode but it ends up dying. the car will not rev and is not derivable due to a severe lack of power. at this point im not sure if its a tuning issue or sensor/mechanical issue. the motor ran fine when it was ran through a stock wire/pcm.
Thanks!
Jesse
1969 Camaro under construction.
1967 firebird. 6.0/t56. Ridetech stage 2. Moser 9 inch. Forgeline wheels.(SOLD)
