    Results 1 to 19 of 19
      May 2012
      Kansas City, Missouri
      exhaust size 2 1/2 or 3 inch
      Got my new ls3 525 hp for performance end what size exhaust is best I have heard small blocks like the smaller for the back pressure. Not sure if the ls is different. I'm usually a big block guy so any help or advice would be great thanks
      I think 2.5" exhaust is good for up to 600hp. It also saves weight.
      May 2012
      Thanks Andrew
      Feb 2011
      dallas, tx
      I installed a 2.5 dynatech exhaust. from headers back a 3" would work fine but with my quadralink i wouldn't want to deal with a 3" tailpipe.
      I highly recommend dyatech muscle max 2.5" exhaust. Great fitment.
      May 2012
      Thanks randy I will check into that
      Apr 2004
      Cedar Rapids, IA
      Jim Hand in the pontiac world did some extensive testing on exhaust systems. Based on the exhaust cooling and back pressure measured going 3" to the muffler and 2.5 for the tail pipes may be the best of both worlds.
      Northwestern NJ
      Quote Originally Posted by rohrt View Post
      Jim used Torque Technologies stuff. I'ved used them before, too. Going with them again on Madge. Good guys!
      Tommy
      Tommy Souren
      "The older I get, the faster I was."
      Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
      Jan 2013
      Cypress, California
      That is what I would think.
      Feb 2011
      dallas, tx
      Mar 2015
      Ice, just curious if those are corsa mufflers?
      Aug 2011
      North Platte,NE
      3" from headers and mufflers and 2.5" tails.
      May 2012
      Wow randy that's a nice looking exhaust tucks in there and gives u some good ground clearance to what type of headers u running and subframe
      Feb 2011
      dallas, tx
      ls3 with stainless works headers and dse front clip
      Maryville, TN
      So I've always associated a stepped down pipe size (3 in > muffler > 2.5 in) with the old farty truck exhaust sound. Guess that's not the case? Have been thinking about this very question myself.
      Dan
      A.K.A: That bald guy
      Find me on Facebook or my personal website.
      - 67 Camaro: Current Project Car
      Jul 2016
      Iowa
      Probably too late to be of any help to thumper877 but I'll share in case anyone else stumbles on this thread (like I did while flipping around the forum over lunch break)
      Reminded me of an episode of engine masters/roadkill that did some comparisons of 2.5", 3" and open headers including weight of all component,etc.
      In this case for an engine putting out more than 600H.P. the 3" exhaust produced more horse and they think debunks the backpressure claims... some quick google/youtube searches and here it is:
      https://www.youtube.com/watch?v=_PVXvHkr-Vs
      Apr 2004
      Cedar Rapids, IA
      Quote Originally Posted by TomsResto View Post
      Nice video. To bad they couldn't keep going with more testing like a X-cross over of tried a mix of 3" and 2.5 tails.
      Since you posted that for edification I thought I would post the JH muffler test.
      http://www.pontiacstreetperformance....p/exhaust.html
      Sep 2015
      I always go big. 3" on all my rides. sounds better and i have yet to ever find it be negative.
      1966 Mustang Coupe
      5.0 EFI- T5
      Fredericksburg, VA.
      The only negative I can see to 3" exhaust might be packaging.
      Steve Hayes
      "Dust Off"
      68 Camaro
      Support the RPM Act
      https://www.sema.org/rpm-faq.
      With that combination of displacement vs. peak power, you could go a couple ways.
      - 3" mandrel bent from collectors with x-pipe into 3" mufflers out to 2.5" tailpipes
      - Same as above, except 2.5" collector back through x-pipe, mufflers and tailpipes
      The relatively small displacement (compared to big blocks) vs. high horsepower, will probably show a low to midrange torque advantage if you go 2.5" all the way. While the 3" down to 2.5" tails would free up a few ponies on the top end at the cost of some low to midrange.
      Also important, research your mufflers to ensure they're providing peak efficiency. Loud is not always best flow (one of the most popular brand of loud mufflers are actually horribly inefficient). Not much point of putting 3" pipes up front if you're going to choke it with mufflers that flow less than 70% (compared to a straight through pipe).
      So it's down to what is more important to you, and what you can package. Either way, make sure it's mandrel bent, includes the x-pipe, and keep the tails 2.5".
