    Thread: wheel spacers
      Oct 2013
      wheel spacers
      Is it safe to run wheel spacers for road race and or autocross. The bolt on style. And how thick is the limit one would go. Thanks.
      Charley.
      Dec 2008
      Detroit
      I cannot say how thick they should be, I think that would be determined by stud length/strength? I will say if I ever had to run them I would make sure they are hub centric on both sides.
      Big dreams, small pockets....
      Chris--
      '72 Cutlass S LSA/T56 Magnum
      Project Motor City Madness
      May 2011
      Chippewa Falls, WI
      Ideally the proper wheel and offset would be best without any spacers, but they can be used if the budget does not allow as long as inspection and wear/breakage is inspected religiously. Also check with any HPDE rules that may rule them not usable.
      Most hub adapters with additional bolts/studs are 1 inch minimum and can go up to 2 inches. I would recommend nothing more than 1 1/2 inch. I have used them, just be sure to check torque on all studs to ensure nothing is loosening up. Anything shorter than 1 inch I would recommend a spacer and longer wheel studs.
      HTH
      Justin N.
      1966 Chevelle
      1992 GMC Typhoon
      1989 Jeep Wrangler CJ 6.0 Twin Turbo
      1981 Jeep CJ7
      Oct 2013
      wheel spacers
      Thanks for the input guys. My car requires a custom BS so trying to keep cost down for a second set of rims and tires
      Charley
      Aug 2016
      Tampa FL
      I have used wheel adapters up to 3 inch in heavy duty off road conditions. wheel spacers and wheel adapters are different in that the adapters have studs. Good quality adapters are pretty much bullet proof, but, they do stress the flanges of your axles. Axle stress increases proportionally to the size of the wheel adapter. If using wheel spacers, Limit is usually considered to be 1/2 inch, as this placed additional stress on the studs themselves. Wheel spacers may also require longer studs to be pressed into flanges to ensure adequate stud extension beyond the lug nuts when wheel is installed.
      Oct 2013
      wheel spacers
      Thank you didn't know they were different names for the design.
      Charley
      Dec 2008
      Detroit
      I'm sure there are others, but here is the company i fund when I thought I needed rear spacers.
      http://www.motorsport-tech.com/
      Chris--
