      Socal, Ca
      Deleting both sets of O2 sensors?
      Is there any reason to keep both front and rear O2 sensors?
      Apr 2012
      Woodstock, IL
      Do you know what O2 sensors do?
      SchwartzPerformance
      Socal, Ca
      Yes, I do. But...long story short... Normally, I would delete the rear O2 and keep the fronts with a maf tune. A sand rail guy was trying to convince me that a speed density tune with no O2 sensors was better. I didn't know if something brand new had come out for the Ls motor that I didn't know.
      Define "better." If you want the ECU to function in closed loop, the you need the pre cat O2 sensors.
      Socal, Ca
      Better... I don't know what he meant by better.
      I feel that maf and front O2 sensors will work just fine.
      Quote Originally Posted by DJW32 View Post
      I would agree with that.
      Aug 2008
      jacksonville,fl
      I think the speed density has the advantage of not having to buy 2 ea 02 sensors & worry about them going bad, same for maf. Other than that ,speed density lacks the fine tuning on the spot capabilities of a closed loop system & is more reliant on the MAP sensor for any input.
      Speed density may be better for an off road sandrail that sits up more than it gets used & doesn't have to run as perfect, not for the street.
      NOTHING new here, speed density was first in most early efi systems, or used for a little while before being discontinued by factory. Also easier for some to aftermarket tune.
