    Results 1 to 10 of 10
    Thread: New From Tampa
      Aug 2016
      Tampa FL
      New From Tampa
      First, let me thank all of you for my extensive use of this site as a knowledge base
      I have visited as a guest for the past 4 years, and have finally made the effort to join
      Aug 2016
      Tampa FL
      My project 67 camaro is mostly resto-mod, but with an enphasis on pro touring suspension and drive train efficiency
      Welcome from Orlando!
      SMSgt Ty Ingle, USAF
      "CF71" - Freedom Bird
      Aug 2016
      Tampa FL
      Body and paint are done with custom subframe connectors welded in and hotchkis rear sway bar bracket welded in as well
      Front sway bar is hotchis as well with spohn connectors
      Rear springs are Global West reverse eye with delrin mounts, with front spring arms also from Global West
      QA1 coilovers add to front response and will probably be joined by QA1 adjustable rear shocks
      Aug 2016
      Tampa FL
      Original engine block was line bored and rebuilt with a solid roller cam with modest power goals of 300hp and 275 ft lb and an aggressive goal of 30 mpg highway
      Engine dyno results are 350 /350 with a relatively flat curve that I am Very happy with
      American Powertrain TKO600 Connects to a 8.5" 10 bolt posi from a 73 ss nova
      Rear gears are changed from 3.73 to 3.23, but may change back if performance suffers.
      Aug 2016
      Tampa FL
      Hydroboost feeds stainless brake lines to corvette c4 /c5 hybrid brakes on all 4 corners
      18x8 and 18x9.5 Coys wheels complete ground contact with Michelin pilot super sport tires
      Aug 2016
      Tampa FL
      My thanks to all of you !!
      Aug 2016
      Tampa FL
      In the beginning
Size:  181.3 KBName:  2013-10-23-B.jpg
Size:  155.9 KBName:  2014-05-22-B.jpg
      Jun 2014
      Temecula, CA
      Welcome! I am on the other side of the bay (Dunedin). Are you doing all the work? What status is the car now?
      Scott Parker | Co-Owner | Middle Out Media
      Aug 2016
      Tampa FL
      Most of the work has been done at GM Muscle in Hudson.
      Car is currently home for wiring, Then off to upholstery
